Results 1 to 3 of 3
    near Rockhampton
    6,216
    Default Trailer with onboard brake system blowing fuses
    Have a trailer here with an on board brake controller.
    Issue is the plug was rewired (not by me) and while it looks OK, when you apply the brakes in the towing vehicle, the trailer wheels brake momentarily, then the brake fuse in your vehicle blows.
    How are electric brakes supposed to be wired up?
    The controller installed is the same as this one
    https://www.ebay.com.au/itm/Brake-Co...-/323078407323
    Sep 2005
    Bendigo
    60
    419
    It should be wired up as per the manufacturers recommendations.
    Yonnee's Avatar
    May 2007
    Tooradin, Vic.
    52
    1,318
    Not having played with that controller, I can’t comment on it, but in general with most installations and controllers, if there’s a short in the blue feed wire that powers the magnets, the system should shut down. That can be either the wire itself from the controller to the brakes, or the magnets have worn through and are shorting in the drums.
  1. Blowing fuses
    Last Post: 16th Jul 2016, 07:20 PM
  2. Brake controller for tandem trailer
    By chambezio in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 11th Jan 2013, 11:05 AM
  3. Trailer brake light problem - help please!
    By deewhy in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 13th Jun 2010, 02:41 PM
