Results 1 to 11 of 11
6th Apr 2018, 09:48 PM #1Diamond Member
- Aug 2006
- 1,105
Wheel adapters for trailers, are they legal in Victoria?
Hi all,
Just wondering if wheel adaptors fitted to a trailer would be legal in Victoria. Reason being I have an old trailer here which seems to be fitted with some old Volkswagen Bus wheels. Now the tyres on there are old and require replacing, I couldn't find any numbers on there (wouldn't surprise me if it was an original tyre from the 1950's lol. They are 15" wheels and from google research I can fit a tyre up to 205 wide on them.
I noticed that you can get wheel adaptors to fit ford wheels onto them which would be an advantage as I have some ford spares around that would suit a trailer. Also would depend on the cost of the adaptors as whether it is worth doing or not.
7th Apr 2018, 06:03 PM #2China
- Dec 2005
- South Australia
- 1,656
I would be surprised if they are legal in VIC, they are not legal SA, I found out the hard way when I borrowed a mates trailer, few years ago ( $300 )
7th Apr 2018, 10:36 PM #3Most Valued Member
- 5,944
That was an expensive borrow!!!!! Could have bought one at that price.
8th Apr 2018, 12:50 AM #4China
- Dec 2005
- South Australia
- 1,656
Yeh! I would hate to think what the fine would be now, given the massive jump in fines in SA
Ended up a overall nightmare defected on the spot would not allow it to be towed had to be a tilt tray, then would have to go to Regency pk to have the defect removed another $250 fee.
Mate ended up up using as a farm trailer.
8th Apr 2018, 02:03 PM #5Member
- May 2012
- Oakleigh, Victoria
- 55
You could probably replace the axle and hubs for about the same price as adapters. Might get away with hubs only if they've got common ford or holden bearings.
https://www.swiftcotrailerparts.com.au/Trailer-Parts-Master-X20/39mm-ROUND-LAZY-AXLE-SS139/54-inch-1370mm-Axle-39mm-Round-Holden-Bearings-TPHA39R54N.html
8th Apr 2018, 02:20 PM #6Diamond Member
- Aug 2006
- 1,105
I thought about that, but this is a drop axle which would probably be an advantage. I will have to measure to see if I can just change the hubs, that would be a lot cheaper. Is there any measurements out there for the ford/holden bearings so I can compare with mine.
8th Apr 2018, 08:15 PM #7Member
- May 2012
- 55
Trigg Bros Pty Ltd for hub dimensions
Google is your friend for bearing dimensions.
Pic below has dimensions and part numbers
9th Apr 2018, 03:04 AM #8
You could also look a bit further afield. I found out by accident that Magna wheels fit on Ford hubs for example. In any case, whatever common hub you find to fit, the tyres from your Ford spares may fit wheels from other common makes.
Cheers, Joe
9th Apr 2018, 07:53 AM #9Member
- May 2012
- 55
Might also be possible to re drill the hubs to a new pcd. That would depend on the design of the hub if it's suitable.
There are 14" rims to suit VW wide 5 stud pattern too as jhovel suggests, you just have to hunt around a bit.
Here's some on ebay https://www.ebay.com.au/itm/VW-Split...EAAOSwQS1Z6we0
9th Apr 2018, 08:37 PM #10Diamond Member
- Aug 2006
- 1,105
Thanks for the measurements, I will measure up mine when I have a bit of time. Hopefully I get get away with a hub swap. If not I suppose it is not that big of a deal to just put new tyres on the VW rims I have here. I would fit 205's to them as that seems to be the maximum. I suppose profile won't matter to much, something common.
10th Apr 2018, 12:19 AM #11Most Valued Member
- 5,944
OT: Metalwork, Automotive bush press adapters
By .RC. in forum METALWORK GENERALReplies: 11Last Post: 12th Oct 2015, 05:27 PM -
hollow axles legal???
By matt9422 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 25th Jul 2011, 12:36 AM -
What's legal in NSW?
By colinpr in forum TRAILERS & OTHER FABRICATED STUFFReplies: 10Last Post: 21st May 2010, 10:33 PM -
5MT - 5C Collet adapters
By Gavin Newman in forum METALWORK GENERALReplies: 9Last Post: 3rd Mar 2010, 09:24 PM -
Gas converter adapters
By DeltaNegative in forum METALWORK GENERALReplies: 4Last Post: 29th Jul 2009, 10:04 AM
