Results 16 to 18 of 18
Thread: Advise On Trailers
25th Dec 2017, 06:54 PM #16Intermediate Member
- Jan 2009
- Auckland, NZ
- 32
I would get a 8x4’ trailer. Make sure it is a bit bigger than those measurements so you can put a 1220x2440 sheet of ply inside the box body. A set of bearing buddies (auto greasers for the wheels) are good value to make the bearings last. Look for a galv trailer or you will be painting and fighting rust later.
7th Jan 2018, 11:44 AM #17
I find that most trailers are not made heavy enough to carry their rated load, I usually hire a big heavy tandem plant trailer if there is a heavy item to be moved, and it towed wuth a loaded Landcruiser ute, which has nearly a ton of tools and parts on it at all times.
Tows 3 ton plus trailer without a problem and I am heavy enough to control it in an emergency, (been there , some fool cut in ), no damage to me or load , some black paint on their Prado from my bullbar .
18th Feb 2018, 09:49 AM #18
The best thing about trailers, particularly if you're handy with a welder, is their ability to be modified to suit your needs. I have done several customer's trailers where I weld in an SHS upright in each outer corner, into which I then fabricate a 'H' frame (that's easily removable when not in use) to carry longer lengths of timber/pipes/ladders or whatever else you can think of. I've also used this method to fit a cage setup for a Scout Group. The cage sides slotted into the corner uprights, and the front and rear gates slotted onto vertical tailgate hinges, but making them all come apart allows for easy storage against a wall when not in use. And if you're REALLY careful with your measurements, fitting your uprights and making your sides and gates identical to their opposite siblings, then you don't have to muck around with Left/Right, Front/Rear, as they will be interchangeable.
Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Welder purchase advise
By bishboy in forum WELDINGReplies: 8Last Post: 14th Feb 2016, 09:00 AM -
Very first TIG welds. please advise
By Zumanity in forum WELDINGReplies: 5Last Post: 9th May 2014, 03:28 PM -
Looking for advise buying welder
By Rod Gilbert in forum WELDINGReplies: 9Last Post: 13th Jan 2013, 08:00 AM -
advise need please
By boyblueeye in forum WELDINGReplies: 8Last Post: 13th May 2012, 12:22 AM -
Powdercoating advise
By Geoff Dean in forum METALWORK GENERALReplies: 7Last Post: 26th Jan 2006, 11:03 PM
