Results 16 to 29 of 29
8th Aug 2016, 06:11 PM #16
Up date here. Full chassis. Ok well there is some detail missing still and it is just the skeleton
And from the rear
A little detail on the proposed suspension
Hydrolic lift not to scale but to raise and lower the unit so it can sit right on the ground
Overall length is about 5400mm
Could be some time and some on the drawing board but good to get some feed back as I mentally perfecr it for my needs.
I do have some other ideas aroind the suspension and may get an alternative up soon.
Dave TTC
Turning Wood Into Art
8th Aug 2016, 09:01 PM #17Pink 10EE owner
- 6,216
How do you change the tyre when it goes flat?
8th Aug 2016, 10:04 PM #18
Removable panel on the inside
Rainy day .... no problem. Change the wheel under cover
Dave TTC
8th Aug 2016, 11:58 PM #19Any thing with sharp teeth eats meat.
People are made of meat.
9th Aug 2016, 12:07 AM #20
Seriuosly dave that whole suspension concept ain't going to fly.
Have you looked at the independent suspension systems currently on offer?
Any independent suspension system has to have some sort of wide base pivot like a wishbone ...... and I do not know of a single automotive spring system that works in tension.
What you are trying to do would be easier to achieve with a drop axle , trailing links, panhard rod and airbags.
If you want a raise and lower traler bed that drops all the way to the ground, there are some existing designs out there ...... they are complex, heavy and expensive to build.
as for changing that tyre ....... it ain't going to happen ...... you need a full open wheel arch.
9th Aug 2016, 12:19 AM #21
this is what one of the available independent systems looks like
9th Aug 2016, 01:44 AM #22
The red one is a hydroluc ram to lift and lower.
The spring and strut is in compresion however you are right about airbags. Chris sent me a youtube link earlier which was educational.
Dave TTC
9th Aug 2016, 08:44 AM #23Intermediate Member
- Dec 2013
- Mt Waverley Vic 3149
- 81
- 44
I have to agree with Soundman, I can't see it working. Have you sought any advice as to registration requirements - I suspect that you will need engineering certification for registration and / or insurance.
We can talk about it in more detail when you are down.
Bob
14th Aug 2016, 07:56 AM #24Senior Member
- Sep 2008
- texas, queensland
- 248
Duratorque suspension system works well , had it on our tandem trailer for our ski race boat towed it all over the country for years Duratorque Suspension - Trojan Trailer Parts & Components, trojan, trailer, component, duratorque, suspension, hub, brake, braking, coupling, towball, wheel, jockey wheel, flag bag, load leveller, wheel lamp, brake controller, wheel mount, leaf sprin
'If the enemy is in range, so are you.'
18th Aug 2016, 03:52 PM #25Most Valued Member
- 5,942
Hi Dave,
Had this emailed to me as part of another posting. Something along the lines that you're looking at, copy and paste into Google, Drop Deck Depot
Drop Deck Depot is a unique trailer manufacturer in that we specialize exclusively in one platform – hydraulic drop deck trailers.
KrynLast edited by KBs PensNmore; 18th Aug 2016 at 04:03 PM. Reason: Couldn't get link to work
4th Sep 2016, 11:33 AM #26
Take a look at how Drake Trailers make the suspension used on Low loaders .
These have what you require only much heavier , also a tried and tested design .
They can be lowered hydraulically each axle is independent , inside tyres are a pain in the butt to change when loaded .
4th Sep 2016, 07:22 PM #27
Thx Mike. I'll google it
Dave TTC
7th Nov 2016, 12:32 PM #28Member
- Jun 2009
- Toowoomba QLD
This sort of setup may work better:
Race Car Trailers, Car Transporters, Race Trailers USA, AUS, NZ
8th Nov 2016, 07:18 AM #29
I like that a lot
Dave TTC
Slimline Seal Stub ID
By Burnsy in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 29th Oct 2013, 08:47 PM -
Stub axle welding procedure
By gallegos in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 27th Sep 2013, 09:34 PM -
Stub axles and using RHS for the axle
By surfin in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 3rd Jul 2010, 12:58 PM -
independant suspension
By Tor in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 29th Mar 2010, 09:42 PM -
6 stud toyota stub axles for trailer
By YarrD in forum TRAILERS & OTHER FABRICATED STUFFReplies: 35Last Post: 10th Aug 2009, 11:59 PM
