Results 1 to 4 of 4
    Aug 2010
    Glenbrook NSW Australia
    125
    Default quick fix trailer liner
    For those who maybe have the same problem
    I have a steel trailer with the floor rusting out,
    First thought put new floor in.
    Second thought is the cost and effort worth it with the whole thing is getting ruster.
    Third thought what if I do a quick fix that will last 4-5 years then see if I still need a trailer.
    The answer was a new panel sheet that a mate uses for wet areas and I have been using his off cuts for spoilboard in the cnc mill as it is not affected by the coolant.
    So two 18mm thick sheets latter and 10 minutes of saw time a few screws in the floor beams and some urethane sealant. One trick was the sides and front panels have no screws as there tuck under the top lip and the floor holds them against the side and front.
    Had to cut and weld the bottom of the tailgate to allow for the new floor height.
    The board is called core light from nover and other places. link to product
    Corelight Wood Plastic Composite Waterproof Panels, Nover Eastern Creek NSW 2766
    Have fun now
    Russell
    vapourforge.com
    May 2011
    Murray Bridge S Aust.
    5,959
    Nice quick repair. Did you cut out the rusted remains of the floor? Asking, just incase that some of it falls onto the road causing an accident!!!!!
    Aug 2010
    125
    Your point is a good one and no I did not cut out any floor.
    I think I will go and put a few more screws around the rusty end and hold it all in place.
    vapourforge.com
    May 2010
    Lower Lakes SA
    58
    2,607
    I've had similar ideas, but my concern is does it accelerate the rust by trapping moisture? And now that it's hidden is there more chance of a safety issue going unnoticed?
  1. P&N quick cut dies
    By kenny_10 in forum WANTED TO BUY
    Last Post: 7th Jun 2016, 07:39 PM
  2. teflon liner in bulk?
    By danielhobby in forum WELDING
    Last Post: 16th Feb 2014, 08:23 AM
  3. where to get ute liner paint
    By Gaza in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 16th Mar 2012, 09:28 PM
