Results 1 to 11 of 11
Thread: Spring hanger welding
14th Apr 2016, 10:40 PM #1Member
- Mar 2007
- Brisbane
- 33
- 58
Hey everyone,
I need to weld some new springs hangers onto my tandem trailer. I've done a fair bit of welding before and just wanted to know the best/strongest method to weld it. Are any of these examples that I've found on the internet acceptable?
Also, is it okay to weld around the whole perimeter of the hanger or just down parallel sides like so | |
With the draw bar, have read not to weld across it but down the sides only. Is there any other way to brace them up? Any pictures would be very helpful. I don't carry much weight but I'd rather over engineer it for peace of mind.
15th Apr 2016, 01:38 AM #2Most Valued Member
- 5,942
Is this a repair or a build? Welding down the sides is perfect, if you weld across the chassis, you stand a very good chance of problems with the chassis starting to crack. Same as welding down the sides of the draw bar is good, for the above reason also.
How do you mean brace the drawbar?? What size and type of material, are you using for the drawbar? Stating the size of the trailer would help with the drawbar sizing too please? It's no good saying a 75X50X5 mm angle is ok for the drawbar without knowing if the trailer is a 3x4 or a car trailer????
15th Apr 2016, 03:06 PM #3Member
- Mar 2007
- Brisbane
- 33
- 58
Hi Kryn,
This will be a repair job bud. I had built this tandem trailer a while back and some of the existing framing needs to be replaced as rust has gotten to it pretty badly. So I need to remove the existing hangers and drawbar and weld them onto the new section I'm putting in.
Drawbar bracing as in how it's showed in the attached picture. Adding a piece of angle and welding where the green lines are. I'm thinking, this should be fine as long as I don't weld across?
Trailer is an 8x5 but has a single cab alloy ute tray on it. Drawbar is 75x50x3.
15th Apr 2016, 06:48 PM #4Most Valued Member
- 5,942
If the drawbar is 75X50X3 I'd be a bit worried, minimum I'd go for is 75X50X6. There is no need for the extra angle on top of the drawbar to connect to the chassis frame, welding underneath would be sufficient. To much weld can be as bad as not enough. If you're concerned about it bending there, a piece about 750 long welded to the underside of the drawbar, (basically making it a box section will stiffen it up), go back about 150-200 mm under the trailer.
17th Apr 2016, 11:27 AM #5Member
- Mar 2007
- Brisbane
- 33
- 58
Thanks mate, I will look into that.
With my first post, can I brace the centre hanger like it's shown in the attached picture with a piece of flat bar cut into a triangular shape?
Also, would you have any recommendations on a decent brake kit? I don't carry much heavy loads too often so was looking for a bare essential brake setup. Drums or disk etc.
18th Apr 2016, 12:35 AM #6Most Valued Member
- 5,942
You could brace it if you wanted to, I don't think I've ever seen one done though.
With regards to braking, your choices are Hydraulic override, Mechanical override or electric brakes, which will be more expensive to set up initially.
The beauty of the first 2 is that anyone can tow your trailer legally, with the electric brakes, it requires a controller fitted to the tow vehicle, unless someone else has one fitted to their vehicle, they can't tow your trailer. Sometimes thats a good thing.
Drum or Disc, can be operated off all 3 systems, discs pads are easier to change, not having to dismantle the drum/bearing assy.
If you go through a lot of water, discs dry out quicker, which is why a lot of boat trailers use them.
It all comes down to personal choice. Hydraulic override with drums would be the cheapest effective braking, USE synthetic brake fluid, as it won't take in moisture as does ordinary brake fluid. Mechanical overrides on drums are basically a thing of the past, cables stretch, cable clamps rust up and the cable has to rub in loops along the chassis.
18th Apr 2016, 07:05 PM #7Member
- Mar 2007
- Brisbane
- 33
- 58
I think you've persuaded me to go with the disk brake setup. I really don't plan on replacing stretched cables etc.
Now I can't decide whether to use duragal 50x50x2.5 or just use the painted stuff. I've got access to a gas/gasless CIGweld. Have read that using flux core, gasless will be fine with duragal. I still plan on griding off the stuff before welding.
18th Apr 2016, 07:49 PM #8Most Valued Member
- 5,942
I'm not a fan of gasless stuff, I don't think it's structurally sound welding, full of porosity, I could be wrong, my partner always says I am.
18th Apr 2016, 08:03 PM #9Diamond Member
- Jun 2010
- Canberra
- 1,322
I like duragal 'cause you don't need to paint it, so once the last weld is done, she's good to go. Also, the duragal coating is *designed* to be welded through - you can certainly grind it off if you like, but that was not the intention of the engineers and chemists etc. who developed the coating.
As for gasless wire, provided you don't mind smoke and a bit of spatter, and own a wire brush to remove the powdery slag, it makes perfectly fine welds.
22nd Apr 2016, 04:14 PM #10Member
- Mar 2007
- Brisbane
- 33
- 58
26th May 2016, 06:00 PM #11Banned
- Feb 2015
- Oz
- 73
- 459
Besides a few box trailers made from uncoated RHS I've also made a number of items from Duragal including a couple of boat trailers, one for a Hobie Adventure Island the other for a Walker Bay 10, using just a standard AC stick welder. Welding Duragal is not a problem and there is no need to grind first; however, you will need to hit the welded areas with cold gal after. Being a box trailer that should last. A boat trailer on the other hand requires constant cleaning and repainting of the welded area as rust spots will constantly appear through the paint. I believe the spool I have in my mig is recommended for Duragal but couldn't find any reference to it on the web; however, I did find this:
http://www.bjhowes.com.au/Duragal%20Welding%20Guide.pdf
I haven't read it but there might be something of use.
Good advice here from KBs PensNmore/RustyArc both obviously know there stuff. BTW, Grahame Collins over in the welding forum is a veritable gold mine when it comes to anything welding!
Spring Steel
By Big Shed in forum METALWORK GENERALReplies: 4Last Post: 8th Jul 2009, 09:01 PM -
Spring hanger setting
By Tigershark in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 7th May 2009, 07:57 PM -
how hard - exhaust hanger bracket?
By mugget in forum METALWORK GENERALReplies: 2Last Post: 28th Mar 2009, 11:33 PM -
Spring Steel
By MICKYG in forum METALWORK GENERALReplies: 9Last Post: 27th Sep 2005, 10:41 PM
