Results 1 to 14 of 14
Thread: Aluminium ute tray trailer
11th Sep 2011, 11:32 PM #1New Member
- Aug 2006
- Lithgow
- 0
Hi guys, I was thinking of either making or buying an aluminum tray trailer probably in a tandem. Any pros or cons I should know about before I start. I figure it should last a lot longer being aluminum especially if left with sand or lawn clippings for a period. Thanks
12th Sep 2011, 06:35 PM #2
The only real "Con" I can think of is the height. Generally tray tops are about 6' wide and sit over the top of the wheels of the ute it's attached to, so a trailer is going to be fairly high. Roughly calculating a 600mm diameter wheel with 75'' of wheel travel clearance gives you a tray top nearly 700mm of the ground. Just something to keep in mind for loading and unloading, depending on what you're going to use the trailer for.
However, there's no reason why you couldn't even cut out the wheel arch sections from the tray and have some aluminium wheel arches made up, which would drop the floor level by about 300mm.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
13th Sep 2011, 11:40 PM #3Intermediate Member
- Jul 2009
- Quorn
- 53
- 35
My brother and I made a trailer like you are intending, it's mainly for carting the quads around as the original sides make suitable ramps, even for me to drive the big quad on and off. (It's tandem)
We find the height ok.
I'll see if I can get some photo's of it next time I'm home.
Wahoon.Cheers,
Dion.
14th Sep 2011, 08:25 AM #4New Member
- Aug 2006
- Lithgow
- 0
Thanks guys. I am thinking that it may be the way to go. The other option is maybe galvanized..
16th Sep 2011, 12:24 AM #5
Wouldn't mind seeing some photos Dion.
And I wasn't suggesting that the height was a dealbreaker. Merely that it should be a consideration when building a trailer as it significantly raises the centre of gravity. But for carting stuff that is better suited to side loading, there's nothing better than a flat top tray.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
16th Sep 2011, 12:33 AM #6
You could buy Duragal to weld the frame and still add the Alloy top.
There's a heap to consider when building a trailer that's going to be hot Gal dipped.
- The heat can warp the thinner sheet metal side panels, floors and tailgates.
- Every single RHS tube must have a hole at both ends, either by leaving the ends open or drilling 1/2" holes.
- Not every galvanizing place has a bath big enough to take a trailer.
20th Sep 2011, 08:42 AM #7Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Yonnee is dead on regarding his comments about construction for galvanising. Get it wrong and you have a bomb!
Personally I do not see galvanising as the best option for trailers unless they are for farm usage, such as portable yards etc. I also question the choice of an aluminium ute tray to build a trailer if it is to be used for anything other than light duties.
Ally ute trays are built to a price and typically are bolt together, they are mounted on a rigid vehicle chassis that provides most of their strength and even then suffer from dented floors, rattles and the like as they age.
If it is only to cart bikes and some garden greenwaste it will probably be ok, but if you are carting firewood or the like I would rethink the idea.
You will be spending large amounts of dollars, (this trailer will need brakes etc), so you must be happy with the end result for years to come.
As a matter or interest, how many people are aware that the regs for safety chains have changed and now load rated chains with a stamp on every link must be used, (no more galv chain from the local hardware store!).
20th Sep 2011, 03:10 PM #8son of a blacksmith
- Roxby Downs Sth Aust
- 47
- 205
ive got an aluminium tray floor with raised ridges, its a real pain in the neck when i have to shove stuff like gravel and sand. if you can get the floor in flat plate i think that would be better suited for what you want to use it for.
20th Sep 2011, 06:32 PM #9New Member
- Aug 2006
- Lithgow
- 0
Thanks guys. Still giving the construction some thought. Was looking at independent rubber suspension but was wondering how the axles usually mount to the chasis and if this was a better way to go rather than springs. Was also wondering how much more expensive it may be.
22nd Sep 2011, 01:21 PM #10Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
22nd Sep 2011, 09:37 PM #11Most Valued Member
- Sep 2010
- Lebrina
- 1,910
26th Sep 2011, 07:02 PM #12
You're right, there's so many unsafe trailers on Australian roads and a heap of them are brand new!! There's a big difference between being part of the regulations, and actually being enforced. Most manufacturers have the ability to register the trailers they make and sell, so there's quite a few manufacturers who will fit substandard parts once they have the registering process setup.
26th Sep 2011, 10:47 PM #13Intermediate Member
- Jul 2009
- Quorn
- 53
- 35
My brothers Ali tray back trailer.
Mmmm, that didn't work, photo's didn't attach.Last edited by Wahoon; 26th Sep 2011 at 10:48 PM. Reason: More text.
Dion.
26th Sep 2011, 10:59 PM #14Intermediate Member
- Jul 2009
- Quorn
- 53
- 35
Photo's attached this time
Dion.
Another Tray Trailer
By GU2001 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 31Last Post: 21st Feb 2011, 08:49 AM -
Trailer build from dropside ute tray
By surfin in forum TRAILERS & OTHER FABRICATED STUFFReplies: 7Last Post: 1st Jul 2010, 07:31 PM -
Using a ute tray for a trailer
By spooled in forum TRAILERS & OTHER FABRICATED STUFFReplies: 12Last Post: 26th Apr 2009, 11:32 PM
