Results 1 to 10 of 10
Thread: hollow axles legal???
22nd Jun 2011, 10:37 AM #1New Member
- Feb 2011
- Dubbo
- 4
Hello, i was wondering if hollow axles are legal in nsw as i cannot find any information form the RTA of the VSB1?
Cheers Matt.
22nd Jun 2011, 02:30 PM #2Novice
- Apr 2008
- Pacific Haven QLD
- 79
- 12
22nd Jun 2011, 03:07 PM #3
Is solid bar really any stronger than thickwall hollow tubing in this situation?
My water cart(not the road...)has been bouncing around for two seasons using hollow tube/welded stubs which is solid mounted(ie no suspension). Its still straight as the day I made it even though its carrying 1Ton+ every load!....................................................................
22nd Jun 2011, 09:53 PM #4
Dose the fear of saying yes to anything have everyone scared.
There is nothing to say they are not legal in the regulations.
You can purchase weld in stubs at any trailer supply place.
I have owned/built several trailers with heavy wall hollow axles and never had a problem.
Fillet weld around the end of the tube and 2 plug welds about 25mm from the inside end of the stub, if the weld breaks/cracks then the stub can't come out of the tube.
Repaired a dual hollow axle car trailer recently that had the front shackle fall off the frame at speed and ended up wraping the front axle in behind the rear axle, it all stayed together, badly bent but nothing seperated.
If you follow all the regulations and have no idea of how to weld or what materials to use and your trailer falls apart and hurts someone, then you will be liable!
23rd Jun 2011, 12:07 PM #5Intermediate Member
- Dec 2007
- Home
- 29
25th Jun 2011, 08:57 AM #621 with 19 years experience
- May 2004
- Sunshine Coast Queensland
- 53
- 52
This got me curious so I've just spent the last 45 minutes searching NSW licensing, the ADR's and vehicle standards.
Suprisingly there is no standard that I can find on this.
If this is a trailer you're going to license, call the place you're taking it for inspection and see what they will pass. If it's repairing a licensed trailer go with common sense.
Personally, I would not bother with hollow. You're looking at around $30 for a pair of stubbs which you'd need to get welded on to the axle (and for a job like that you want it done right) where as a 39mm beam axle will set you back $47 for 47 inch up to $66 for 80 inch - these are Qld (Active Fabrications) prices but I guess NSW would be similiar.
5th Jul 2011, 04:52 PM #7Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
6th Jul 2011, 07:02 AM #821 with 19 years experience
- May 2004
- 53
- 52
Why would you bother though?
Depending on size you're looking at $32 a pair (minimum) for 39mm stub axles plus the tube and welding - an 80 inch solid 39mm axle will only cost $66.
For such a little saving you might as well go the solid axle.
Legal does not mean smart, the regs say a trailer is legal with one safety chain but I would never own a trailer that doesn't have two.
9th Jul 2011, 10:32 AM #9
For smaller stuff, I agree. If your making an axle yourself, the only real advantage is the infinite adjustability of your axle length before you weld it. Otherwise, there's no discernible difference between hollow and solid, cost wise, rated capacity or weight.
It's when you get into the higher rated axles that there can be a significant weight saving by having a hollow axle. But... this is not something I'd recommend for the average backyard workshop.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
25th Jul 2011, 12:36 AM #10
I do not believe there is, nor can there be any reason that a hollow axle can be made illegal in principle.
Because there are a great many vehicles that have in effect hollow axles in some form.
Large semi trailers for instance do not have solid axles, nor do most pasenger cars.
But the practicality is being able to guarantee that a given axle performs to the specification required.
There is a both implied and specificaly stated obligation to keep track of the origin of functional trailer parts you use and be able to justify how they are rated for strength and function.
If you buy a complete axle, you can point to it and say, I baught it from so and so and they published this rating for it, I have used it in accordance to their publised data.
If you have access to engineering support you could very easily fabricate an axle with a hollow centre tube, and point to the engineering documents and say this is how the rating was derived.
But for most of us we have no ability to justify and document such an axle.
So when you fill in the " self assessment for light trailers" form, that you will sign at the bottom, assuming responsibility for the life of the trailer, where do you get the figure for "load rating of axle".
There are a great many things that are very reasonable to make and or fabricate for a trailer as a private individual.
But there are three things it is wise to buy from a reputable and tracable source, the axle, the springs(or suspension) and the coupling.
People are made of meat.
how much can two 40mm axles carry?
By journeyman Mick in forum TRAILERS & OTHER FABRICATED STUFFReplies: 10Last Post: 13th Mar 2011, 10:11 PM -
Stub axles and using RHS for the axle
By surfin in forum TRAILERS & OTHER FABRICATED STUFFReplies: 9Last Post: 3rd Jul 2010, 12:58 PM
