Results 1 to 9 of 9
Thread: tyre to leaf spring clearance
10th Jun 2011, 11:20 PM #1danielson
- Dec 2009
- broadford
- 63
- 213
hi all, can some one advise from experience the minimum distance one should have between sidewall of 31.5 x10.5 offroad tyres and side face of leaf springs (7 leaf x65mmx1080 long)to ensure not to damage tyres on an off road camper.thanks ,danny
12th Jun 2011, 03:56 PM #2
Where I work, we don't normally have more than 40mm no matter what the tire used. More than that will only put more leverage on the axle because of the overhang. There may be other opinions out there, but this has been our policy for the 30 years since I started my trade.
RobertCheck my facebook:rhbtimber
12th Jun 2011, 11:01 PM #3danielson
- Dec 2009
- broadford
- 63
- 213
today i assembled bearings,brakes,welded on mountng plates and pads and wheeled it under the trailer,i ended up with 20 mm between sidewall and spring leaves when fitted with fats,when i put split rim on with standard rubber i have 60mm.was a little concerned about overhang so went with a 45mm axle even though trailer should'nt go over 800kg loaded.thanks for your comments.cheers danny
19th Jun 2011, 10:46 AM #4
As Robert said, 1-1/2" or 40mm is usually the norm. Being a single axled trailer, you're not going to get a lot of sideways movement of the wheel (if alot of suspension travel at all), so even the 20mm should be fine.
Also, the gap between tyre and spring should hardly change at all... it's the gap between the top of the inside of the tyre and the inner guard that will change with axle/suspension movement.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
20th Jun 2011, 11:37 PM #5Intermediate Member
- Jan 2008
- Sunshine Coast, Qld
- 43
Following on from the above, the gap is determined by your nominated axle length (as a result of your calculations) . . . so when I ordered a non-standard length axle a year or so back , I was told that axles are made in increments of 1". Is that standard for the trailer industry or do other suppliers in other areas make axles to an exact length?
Not a big deal obvioulsy but might be something other DIYer's might need to take into account when working out the gap/axle length?
21st Jun 2011, 12:20 AM #6
21st Jun 2011, 12:43 AM #7
If you order your axle directly from the manufacturer, the axles are cut from 8.0M bar stock, so you can order an axle cut to whatever measurement you like. With some companies you have to be a little insistant that you want it that particular length.
Funny story... when I worked at Melbourne Trailer & Caravan Supplies, for a while I ran the Repair shop, and in the same factory was the Independent Suspension fabricator and the Bulk Steel rack and CNC cutting machine. Just about all the axles are made to an Imperial measurement in 1/2" increments, however, the CNC is in Metric, so the bloke running the cutting machine calculates the Imperial to Metric for the CNC. I needed an axle for a Caravan we were modifying (fitting 17" HSV wheels), and the clearances were critically tight, so I measured and put forward my order in Metric. But for some strange reason, the production office then calculated the measurement into Imperial, and rounded it to the nearest 1/2" for the CNC operator to convert it back to Metric... see the problem??Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
21st Jun 2011, 08:16 PM #8
We order all of ours with a face to face measurement and they come back almost to the millimeter preassembled. There seems to be some variance in the lengths, on a tandem trailor that has both axles made at the same time from the same company may be differing lengths of up to 5mm, but that really isn't an issue. I would suggest that ordering in 1" increments may be the resellers requirements.
Just my thoughts.
21st Jun 2011, 09:29 PM #9
"Stock" sizes are in 1" increments, and they are usually what's carried by companies who don't actually manufacture the axles themselves, and even then they'll only carry lengths to suit 4', 5' & 6' wide trailers.
THe difference in the pair of tandem axles would be a 9" Hydraulic & Lazy combination. The drum casting used by some manufacturers doesn't have the same bearing to face offset as all the other hubs and drums in the range, so the axle has to be made 16mm shorter, however, they usually round them to 1/2", so they're still out by 3.5mm. And that's if the bloke on the cutting machine is fussy with his tape measure...Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Trailer - tyre to guard clearance.
By lisney56 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 7th Apr 2011, 06:15 PM
