Results 1 to 8 of 8
3rd Aug 2010, 11:18 PM #1
VSB1 v5 - Trailer building Regulations
Vehicle Standards Bulletin VSB1
I've taken the liberty of putting up the link to the current* Vehicle Standards Bulletin for building small trailers under 4.5 tonne. This is pretty much the bible for building trailers and is recognized Nationally.
There are some changes from the previous versions, mainly to the lighting requirements, but I think I've got my head around them. So feel free to ask for any clarifications.
* Revision 5 - June 2009
Glider, Dragonboat, Rowing & Trailer Sailer Trailers - You can build a trailer to carry these items, whose overhang exceeds that of the VSB1 regulations above. Attached are the relevant links to some of the information required for each state. It is suggested that you contact your own state authority to obtain the most up to date information. In some states you are required to carry a copy of the bulletin around with you.
New South Wales (currently cannot find any documentation that allows trailers over 3.7M overhang)
Northern Territory
Queensland
South Australia
Tasmania
Victoria
Western Australia (currently cannot find any documentation that allows trailers over 3.7M overhang)Last edited by Yonnee; 9th Jul 2011 at 12:04 PM.
24th Apr 2016, 01:17 AM #2New Member
- Nov 2012
- Wichita, Kansas USA
- 1
Safety Chains
Thank you for the great information... please... Make the safety "chains" extremely strong, using the shackles that actual have a system to keep them from coming lose. Such as a spring loaded retainer.
I had two close Army Veterans that were killed on a Saturday morning "fun run" (Motor cycle) with a group of about 50 riders (Including his father and other family members) killed when a trailer broke loose from a truck going in the opposite direction with a huge grass area dividing the two directs of traffic. The trailer was used for hauling lawn mowers and such, the tires were in good shape, the trailer was well within specifications, the safety chains had been attached, no speeding involved, a bump in the road caused the trailer to jump off of the hitch, broke the chains, went through the median (the 70+ foot dividing area between the two lanes of traffic flow) striking their motorcycle, they had helmets, experienced riders). The investigation called it an "accident," no one was cited, the trailer was found to be well within the standards, etc.
what happened was two young veterans were killed, and they had two young children, a large group of friends that saw the entire event. There was nothing they could do, some of the other motor cycles had to dump their bikes in a controlled slide so the wheels of their bikes hit the trailer and avoiding being thrown from their bikes. Skinned up but alive.
Please over build, and if you can think of any safety devices to add to the designs, do!
11th Apr 2021, 01:39 AM #3Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
VSB 1 R6 Update
VSB 1 was updated to R6 in Feb 21
https://www.infrastructure.gov.au/ve...222.pdf#page68
18th Nov 2021, 06:57 PM #4
Tried your link and it came up with a "not found" error. Seems the url has now changed to:
https://www.infrastructure.gov.au/si...6-20210222.pdf
23rd Dec 2021, 12:30 AM #5
Changes coming into effect from June 2022, no more ''home made trailers'', main changes is Road Vehicle Standards or RVS you cannot self certify the trailer is compliant as per VSB1. You will now have to apply for approval to build the trailer subject to meeting the eligibility requirements i.e Quality Manufacturing Standard ,and strength testing of the trailer through a RMS approved provider to ensure the draw bar and chain complies ect . The other main change is a Register of approved vehicles RVS an online public data base will hold all the info about who made the trailer and all their details.
I'm also hearing the Govt want to make it a min requirement that trailers are built by licenced body shops and not by back yard welders operators from factories on ABN, i'd say this will come later.
You can still register a trailer as per VSB1 until June 2022 , you can also build one as per VSB1R6 via ROVER but you may not get the approval to proceed and trailer maker or manufacturer will be public record. The safety chain and drawbar testing requirement is still in the discussion phase and will come into effect in due course. I think the outcome will be , more paper work and red tape, higher registration costs and this will lead to higher trailer prices for both new and used.
24th Dec 2021, 07:45 PM #6Senior Member
- Oct 2015
- melbourne
- 473
So, are back yard trailers the cause of many incidents i wonder?
Presumably the same requirement for testing will apply to imports.
2nd Jan 2022, 10:44 AM #7
here is a link with an overview of changes ;
https://www.infrastructure.gov.au/in...w-atm-trailers
2nd Jan 2022, 04:05 PM #8Golden Member
- Jun 2005
- Helensburgh
- 618
Trailer Building
By smidsy in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 28th Dec 2006, 01:43 PM
