Results 1 to 6 of 6
Thread: tekonsha brake unit
27th May 2010, 08:01 PM #1
tekonsha brake unit
i found a tekonsha brake unit at a garage sale and bought it. it has no wiring diagram and the model is 2030 mark12 and has a white,red, black and blue wires coming out the back,does anyone know about these units and how do i wire them up and test if they work?
thanks heaps
greg
27th May 2010, 11:22 PM #2
Have you tried their website? The blue wire is usually the brake wire that goes all the way back to the brake pin in your trailer plug.
28th May 2010, 03:02 PM #3
Gees, a big ol' dinosaur. But still better than some.
Black - 12V+ Battery, through a 20A circuit breaker.
White - Battery Earth.
Red - Negative side (Cold side) Stop Light Switch.
Blue - To #5 pin on trailer plug.
To test:
Hook up the Black onto a car battery. (12V+)
Hook up the White wire onto the same battery. (12V-)
Push the 'fore-aft' slide control all the way in (maximum power).
Slide the horizontal slide control all the way to the left (this is the over-ride control)
Red LED light should come on on the front of the unit.
Hook up the Red wire onto the same point the Black wire is. Again, the Red LED light should come on on the front of the unit.
Tip the unit slowly upward at the front. The LED should go from flashing to bright. Lower the unit down and the LED should go back to flashing. Alternatively, holding the unit level with the woodgrain face facing you, scroll the serrated dial under the unit back and forth. Scroll towards you, the LED should get brighter. Away from you, the LED should dim to flashing.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
28th May 2010, 04:21 PM #4
thanks heaps yonee
i am on dogwatch tonight so i will do a test tomorow when i come home to see if it works and if all good will fit it in the 4 runner
greg
31st May 2010, 08:00 PM #5
it works
thanks for that tip on testing,the little red light come on just when you said it would
thanks heaps
greg
31st May 2010, 08:52 PM #6
All part of the service.
Brake for Cyclone
By m2c1Iw in forum METALWORK GENERALReplies: 3Last Post: 3rd May 2007, 10:01 PM -
Brake press
By gdk3000 in forum METALWORK GENERALReplies: 2Last Post: 1st Feb 2006, 08:58 AM
