Results 1 to 15 of 41
Thread: Plan B trailer build
4th Nov 2009, 01:31 PM #1Member
- May 2007
- Ferndale
- 79
after the failure of plan A
http://www.woodworkforums.com/f184/t...1/#post1051583
I am pretty much starting from scratch now. (can't even use the old springs or axles)
Aim is for a trailer that will hold an 8' plastic dinghy, and associated stuff.
and allow for a camper build to go over top later on.
So far I've decided, main rails and A frame will be 75 x 50 x 4 RHS.
Cross rails will be 75x 40 PFC.
Internal dimension need to be 1210 x 2500, was thinking of just using a sheet of ply for the floor (1220 x 2440). Can anyone help with what spacing the supports would need to be at to use ply, and what thickness ply?
thanks
Frank
5th Nov 2009, 02:06 PM #2Dave J Guest
Hi Frank,
I would suggest one cross the middle and one either side of that which will give you about 600mm spacing. I put 3/4 ply in my 7x4 trailer, it was seconed hand concrete form board. Maybe you could look around and ask a concreter to buy a piece, new supermarkets are the place to go.I have built a few trailers over the years and the sides usualy help keep the chassis ridged. I notice you are using 75x50x4 so you will be able to keep the sides light as it will already have a strong base.
When I build a trailer my aim is to make it as light and strong as possible for the job it's intended for. Some of the high tensile RHS they have out means you can keep the sizes down and still be as strong.
Dave
6th Nov 2009, 10:32 PM #3
I go along with Dave J on this and use 3/4 formply.
Source mine from the big B (price and convenience)
As far as new 3/4 formply goes the Big B normally carries 2 grades. The structural stuff is over $100 a sheet. I normally just use the non structural stuff at around $64. So far havent sourced it for cheaper.
They seem to chop and change the cheaper stuff they buy in. Recon the brown colored stuff isnt as good as black. Personally think it doesnt cut or handle the weather as well.
Think u made the right choice and scrapped plan A.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
7th Nov 2009, 12:04 AM #4Member
- May 2007
- Ferndale
- 79
I examined the span and load deflection tables for plywood, and decided that 12mm with 480 span would suit my use of the trailer. I've ended up with 450 spacing, and I have recessed the ply 15mm (so that in future if I think I need thicker I can go to 17mm with just a small chamfer).
purchased axle, springs, brakes, hubs, and a sheet of 12mm structural CD ply. bought australian ply. apparently all australian ply is metric (1200x2400) whereas the imported is imperial (1220x2440).
so cut my PFC and RHS today, laid it out, levelled it, measure, adjust, repeat 5 times until square.
tack weld, check square.
then out with the angle grinder again to cut the front RHS off.
forgot to cut the holes to allow galvanising to flow
reweld
hopefully do the spring hanger mounts tomorrow (going to make up brackets to spread the load) and the A frame as well.
8th Nov 2009, 08:55 AM #5Member
- May 2007
- Ferndale
- 79
Got all the spring hangers made up (must buy a plasma cutter one day) and tacked on.
Realised my RHS is not as long as I thought it was. Will have to buy some more before I start on the A Frame.
14th Nov 2009, 10:32 PM #6Member
- May 2007
- Ferndale
- 79
The A frame pivots are now tacked on, and A Frame bent, can't weld it until I buy a hitch. Thinking of getting one of those hyland ones, not cheap though.
The regulations are a real pain with their hitch height restriction. I wanted to make the trailer sit at the same height as the landcruiser, but I have to put the hitch lower.
Plan on putting it down between the A frame members, this should just get it low enough to pass.
16th Nov 2009, 04:01 PM #7Member
- May 2007
- Ferndale
- 79
I think I've worked out how to comply with the stupid ADR restriction on ball coupling height (must be between 350 and 420mm from ground to centre of ball with a laden trailer).
If I put two hitch mounting plates (top and bottom) on the A Frame members with the hitch bolt pattern in both plates then mounting the hitch on the top plate will keep the trailer at the right height for the cruiser, and by having the bottom plate (where I can mount the hitch on the underside of it). I can demonstrate the "provision to adjust coupling height to within the regulation range".
Must put a costing up at some stage, trailer parts place is making a fortune out of me.
19th Nov 2009, 10:45 PM #8Member
- May 2007
- Ferndale
- 79
Hitch attachment done, 12mm plate top and bottom of the drawbar RHS. With hitch mounting holes in both plates.
Done one side pin to hold the drawbar frame.
Getting close to turning it up the right way. Althought should probably do the brakes, and wiring routing whilst it is upside down.
2nd Dec 2009, 12:52 PM #9Member
- May 2007
- Ferndale
- 79
Handbrake mount done,
trailer right way up now
and one side on.
was aiming for using it over Christmas, but is not looking likely.
6th Dec 2009, 10:23 AM #10
Nice work...
Looking good so far.
I see the axle with brakes on it, what size / what bearings did you get?
With that chassis, and those spring hangers, you either plan on doing the Oodnadatta Track, or carrying the QE2.
I try to help guys from making costly mistakes, that's why I asked for this trailer section to be started, but it looks like you're doing fine. Keep it up, and keep the pictures coming. Everybody loves pictures!!
Y.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
7th Dec 2009, 09:57 AM #11Member
- May 2007
- Ferndale
- 79
Hi Yonnee,
must revisit your thread to see how your trailer going.
I'm aiming for 1250kg Agg, so have 45mm axle, slimline bearings.
Yeah, its a bit heavy duty, hoping to come in under 500kg Tare, must update my weight spreadsheet and see how I'm doing so far. A lot of the trailer is determined by what steel I have lying around, the spring hangers being one of them. The overall heavy dutiness is determined by me being fed up with trailers that bend.
I reckon its all these forums faults for even starting on this costly build, too many great people out there encouraging others to achieve dreams. Keep it up.
cheers
Frank
7th Dec 2009, 11:29 PM #12
**shudder** Don't even go there. Mine's at a standstill till I get this customers one finished.
Thanks Frank.
8th Dec 2009, 02:02 PM #13Member
- May 2007
- Ferndale
- 79
8th Dec 2009, 05:30 PM #14
How thick are the leaves in the spring? I'm assuming they're only 6.5mm imported springs if that's the rating you've been told they're rated at. I'll check my books at home tonight to double check for you.
If that's the case, then technically you're correct with that weight, however, the VIN tag only states the ATM and the axle capacity, and you can always change the springs to 8mm thick leaves at a later date if you find yourself carrying closer to that weight.
Trust me. It'll be a lot easier to register the trailer the first time @ 1450Kg ATM, even with your current springs, than to try and up it later on. But horses for courses. If you're happy with 1250Kg, then that's cool too.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
8th Dec 2009, 05:48 PM #15Member
- May 2007
- Ferndale
- 79
thanks for that, I may just do that then.
Build me a dog trailer
By jatt in forum TRAILERS & OTHER FABRICATED STUFFReplies: 17Last Post: 29th Sep 2011, 07:42 AM -
Trailer Build
By dazzler in forum TRAILERS & OTHER FABRICATED STUFFReplies: 71Last Post: 8th Nov 2009, 09:03 AM -
Ute trailer build!
By motegi in forum TRAILERS & OTHER FABRICATED STUFFReplies: 7Last Post: 14th May 2009, 12:54 AM -
trailer build
By bobsreturn2003 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 4th Mar 2009, 03:31 PM -
Think I might build a trailer.
By timbo123 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 1st Oct 2008, 11:03 PM
