Results 1 to 3 of 3
Thread: Inverter Unimig 165-190
21st Jun 2009, 03:04 PM #1Novice
- Apr 2009
- Australia
- 10
I'm still looking for a MIG Yesterday I found a 165, a 175 and a 190. They are all around the 1000 buck mark (Give or take a hundred or two). One guy said he thinks the 175 is just a 190 rebadged or the 190 is the 175 rebadged.
Would you bother with them? As I mentioned in other posts, I'm planning to do a bit of aluminium welding (I'm building a camper for my 4wd), I'll be welding checkerplate and square tubing, probably up to about 5mm. I'll be using it off road so the weld needs to be strong. I'll also be using it on steel.
Should I bother with Unimig or can I get better for that money? I was told by the guy that was trying to sel me the Unimig that Lincoln are pretty good.
I'm in Sydney. Where do you recomend I start looking?
Thanx once again.
22nd Jun 2009, 12:18 AM #2Retired
- nsw
- 18
Have a look at the lincoln power mig 180 costs about $ 1200.00 or less
why I mention this one is because you can get a spool gun for it for about $350.00 its very easy to fit and very handy for alu work
27th Jun 2009, 07:54 PM #3Novice
- Apr 2009
- Australia
- 10
OK.
I did it. I got a Lincoln 180c with a spool gun, electronic helmet, gloves and leather aprin for just under $1500.
UniMig Welders
By silash77 in forum WELDINGReplies: 4Last Post: 9th Aug 2009, 08:01 PM -
unimig jasic welders
By northerncat in forum WELDINGReplies: 8Last Post: 14th May 2009, 11:39 PM -
Inverter Welder
By Outbackrr in forum WELDINGReplies: 9Last Post: 17th Jun 2008, 10:40 PM -
Inverter TIG/MMA
By Rossluck in forum WELDINGReplies: 2Last Post: 5th Jul 2007, 04:06 PM -
Inverter Welder
By Just George in forum WELDINGReplies: 10Last Post: 18th Jan 2006, 09:00 AM
