Results 1 to 7 of 7
Thread: Welding gal
9th May 2009, 11:37 PM #1
Welding gal
What are the differences between welding 50x25x1.6 mild steel and the same in gal? can a stick do a proper job or do I need something else like a mig? I vaguely remember welding gal many moons ago and I seem to recall splatter was the order of the day.
9th May 2009, 11:45 PM #2
Either grind the gal coating off or run the rod over the area a couple ot times to burn off the gal , wire brush clean and away you go
Ashore
The trouble with life is there's no background music.
9th May 2009, 11:47 PM #3
Aha, thanks for that. Same amps?
9th May 2009, 11:52 PM #4
Yep their usually enough , you can see the gal flaking off as you go , just remember to give the weld a coat of cold gal after you finish or you produce a sacrificisl area that attracts rust
Ashore
10th May 2009, 08:02 PM #5Member
- Feb 2009
- Kyabram, Victoria, Australia
- 46
- 96
And as another note, other members have suggested that breathing in gal fumes from welding is a rather bad thing, I havnt experienced the things that they say make it bad, but i'll take there word for it.
Matt.
10th May 2009, 10:01 PM #6
It can be really nasty stuff ,
I welded the crap for a long while making Cyclone brand gates.The hot dipped zinc on gal pipes is particularly bad as it is very thick.
It can induce what approximates a fever and in those who suffer bronchial problems has been known to contribute towards their death.
We were given access to drink bottles of milk but if I remember the info in the booklet produced by the AMWU on hazardous metals in the metalwork industry found that that is largely ineffective .
If you are going to weld it at the very least ,use a good fan behind you to blow the fumes away.Other wise get a very good respirator
10th May 2009, 11:00 PM #7
Gidday
At work we just weld over it like anything else IF theres things to be done in volume we wear a respirator! just make sure to burn in with your arc n bear in mind there'll be lots a spatter................U may want to manage this if the appearence of your welds is important
regards LouJust Do The Best You Can With What You HAve At The Time
Gas Axe Welding Set
By watson in forum METALWORK GENERALReplies: 14Last Post: 30th May 2008, 05:52 PM -
Where do you do your welding?
By jmk89 in forum METALWORK GENERALReplies: 16Last Post: 13th Mar 2008, 01:42 AM -
new to welding.
By Bluegum in forum WELDINGReplies: 8Last Post: 24th Oct 2006, 09:22 PM -
welding tip
By mako in forum WELDINGReplies: 4Last Post: 7th Jul 2006, 04:59 PM -
new to welding
By gmcginty in forum WELDINGReplies: 4Last Post: 10th May 2005, 11:31 PM
