Results 1 to 14 of 14
Thread: Transmig 350 EC
23rd Feb 2009, 10:57 AM #1New Member
- Feb 2009
- Kapiti Coast, New Zealand
- 4
Transmig 350 EC
Hi folks, I have an elderly Transmig 350 EC with remote current/voltage control and Transmatic 1 remote feeder. It was made in 1989 and still makes fantastic smooth deep welds, so I don’t want to (and can’t afford to!) replace it. And I have (almost) enough 3-phase current to run it. My only issue is that as soon as power is applied the gas solenoid opens, and as I generally use it for medium hobby fabrication (4x4 mods etc, making a slabbing mill etc) it chews through heaps of argoshield while I’m setting up, moving work, pondering and cursing, etc. I’m not sure if the solenoid is meant to be full-time open, or only when the gun’s trigger is on (ie: actually throwing an arc), or whether it’s changeable. I’ve had a look at the main circuit board but it’s a complex beastie with a load of on-board links and tracing the circuit (I did start!) would take days. And I’d probably get it wrong. So, I was wondering if there’s any chance anyone has a circuit diagram, or a service manual, or even memories of, this model? I'd even be happy to see a sales brochure with a picture (the front panel marking's missing for a couple of the switches, I'm pretty sure I know what they do (it's been welding fine for years), but still... If so I’d love to get my hands on a copy. I’m quite happy to pay if one’s available. I've sent an email to CIGweld but I don't have much hope... cheers, Terry
23rd Feb 2009, 12:32 PM #2New Member
- Feb 2009
- 4
Problem solved
Wow, I emailed CIGweld this morning and they replied almost instantly with both the operation and service manuals in pdf form. Amazing service for a new machine, let alone one entering it's 21st year.... And for reference, the switch on the front panel that was labelled SET and "Something else illegible" is Set and Weld - you put it in SET to set the gas flow (solenoid always on), Weld turns the solenoid on only when current flows Doh!. I'm a very happy boy....
23rd Feb 2009, 02:41 PM #3
18th Apr 2009, 07:10 PM #4New Member
- Apr 2009
- Grafton, Australia
- 3
Hi Terry.
Do you still have the manuals that CIG sent you.
I have the same welder which has just thrown in the towel and refuses to start the wire feed unit yet the feed switch on the front still activates the motor.
If you can help I would be very grateful.
Regards, David
18th Apr 2009, 08:00 PM #5New Member
- Feb 2009
- 4
Hi David,
yes still have the manuals. The troubleshooting bit for wire feed says if the wire can be inched but doesn't feed when the torch switch is initiated, the torch switch or contriol cable is disconnected. I'd try bridging the 2 switch connectors at the welder (the light wire that plugs into 2 spade connectors on the gun cable plug) to check the torch switch - I had 3 guns, 2 had broken switch wires at the switch inside the gun. Also check the 2 fuses on the front panel (although probably OK if the inch feed works). Hope that helps, let me know if you need more.cheers,
Terry
18th Apr 2009, 08:39 PM #6New Member
- Apr 2009
- 3
Hi Terry.
Thanks for getting back to me so quick.
Did try all things you mentioned including testing cables with multimeter but to no avail.
Would it be possible to email the manuals to me as I need to get the welder going urgently?
18th Apr 2009, 08:51 PM #7New Member
- Feb 2009
- 4
copy sent. cheers,
Terry
26th Sep 2009, 11:51 AM #8New Member
- Sep 2009
- Millendon. Western Australia
- 68
- 3
G'day David,
I was interested to read your post as I have exactly the same problem.
Mine is an older machine - probably the same vintage as yours - and is in very good condition. My "inch" feed works flat out but the trigger feed is very very slow even when the feed dial is turned to max.
I would appreaciate any info,
Thanks,
Dane
26th Sep 2009, 11:56 AM #9New Member
- Sep 2009
- 68
- 3
26th Sep 2009, 06:46 PM #10New Member
- Apr 2009
- 3
350EC Welder
Hi Dane
My problem turned out to be crumbling insulation on the wiring loom in the wire feed unit and once renewed it worked fine (wiring was shorting out).
Hope this may be of assistance.
David
26th Sep 2009, 11:14 PM #11New Member
- Sep 2009
- 68
- 3
11th Nov 2010, 11:27 PM #12New Member
- North Shore Sydney
- 6
Can anyone please send me the CIG manuals plus wiring & repair manuals. I'm very interested to see how the 'EC' Electronic Control works. Thanks.
16th Aug 2011, 09:22 PM #13New Member
- mogilla
- 3
hi did you find the problem I have the same problem
perrished wires fixed
I also had a thyristor short and have now replaced both modules with indivual thyristors
the machine works but the wire speed seems to be constant varing the voltage does not appeare to change the speed of the wire
I know this is an old thread but it relevent thanks
16th Aug 2011, 09:26 PM #14New Member
- mogilla
- 3
could the diagrams be posted in this forum ? s they would be usefull
Transmig 200
By quercus in forum WELDINGReplies: 5Last Post: 11th Dec 2008, 09:17 AM -
CIG Transmig 130 Twin
By cliff.king in forum WELDINGReplies: 5Last Post: 6th Sep 2008, 05:50 PM -
CIGWELD Transmig 135
By monkey metal in forum WELDINGReplies: 4Last Post: 1st Sep 2008, 07:05 PM -
setting up transmig 165
By squirrelscuba in forum METALWORK GENERALReplies: 2Last Post: 13th Sep 2006, 09:34 PM -
CIG transmig 150
By timbo123 in forum WELDINGReplies: 8Last Post: 31st Jul 2006, 10:45 AM
