Results 1 to 3 of 3
Thread: Inverter TIG/MMA
4th Jul 2007, 04:38 PM #1
Inverter TIG/MMA
I thought I'd hit the jackpot when I paid $150.00 for a 2nd hand 160 amp Chinese inverter TIG/MMA welder yesterday, but the damn thing doesn't work!
The dual fans start but I can't get a spark out of it on either TIG or stick. I took the cover off and had a good look over it hoping to find a fuse, and it seems to be in good nick. There was a bit of a flash burn on one of the circuit boards, but I'm not sure if it looked bad enough to be the problem. It probably is.
Bit of a bummer. I can take it back without any problems but I wanted one.
5th Jul 2007, 11:13 AM #2New Member
- Tasmania
- 1
I'd be taking it back. I tried to repair an esab caddy once, with some help from an electronics guru.
After putting in $150 worth of new components, it tested brilliantly - Until I struck an arc. Bang and all the new components blown again.
With scorch marks on the circuit boards, forget it.
5th Jul 2007, 04:06 PM #3
Inverter for sheet metal?
By marz1 in forum WELDINGReplies: 4Last Post: 29th Aug 2006, 08:33 PM -
Inverter Welder
By Just George in forum WELDINGReplies: 10Last Post: 18th Jan 2006, 09:00 AM -
Inverter welder for home use???
By Jock_Jock in forum WELDINGReplies: 2Last Post: 12th Sep 2005, 10:49 PM
