Results 1 to 13 of 13
Thread: MIG Welder DOA :(
8th May 2007, 11:09 PM #1
MIG Welder DOA :(
Just got a MIG Welder which seems DOA (dead on Arrival). Trying to feed the wire through the torch and when I plug in and switch on, basically, nothing happens. No noises, no nothing... Could it be the switch? or have I just missed something completely?
Woodworking Product Reviews - Over 200+ Online
http://www.onlinetoolreviews.com
8th May 2007, 11:12 PM #2
8th May 2007, 11:12 PM #3
Can you hear any noise from the machine when you switch the power on, any lights on the machine that should come on but don't?
Have a nice day - Cheers
8th May 2007, 11:18 PM #4
8th May 2007, 11:25 PM #5
8th May 2007, 11:26 PM #6
You need to have the right amount of tension on the little wheel with the groove in it that drives the wire, and the same goes for the spool of wire.
Quick tip:
If at any stage when your welding and the wire stops feeding when you're pressing the trigger.......stop!
Open the side cover and check everything. Wood butcher probably knows this one about the dreaded "Birds Nest"...I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones.
Albert Einstein
8th May 2007, 11:30 PM #7
8th May 2007, 11:36 PM #8
Same thing happened to me.
Pull all that wire off the spool that isn't tensioned and start again. Make sure the end of the wire is not barbed or sharp. You don't want to cut/damage the liner of the trigger cable while feeding it through to the tip.
The wire on the spool needs to be neatly wrapped and tensioned for it to all work properly.I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones.
Albert Einstein
8th May 2007, 11:37 PM #9
...quick run, Grahame's here.
Albert Einstein
8th May 2007, 11:42 PM #10
Also remove the tip off the gun before feeding the wire through so that it won't catch at that last bit
DJ
ADMIN
9th May 2007, 08:58 AM #11
Hi Dean.
There is only a little info you have given the forum to work with.
Is the machine old or new ?
With out knowing what brand of machine or model it can be hard to say ,but the intermittent nature of the fault indicates a loose connection.
My guess on where that is likely to be is at the trigger wire connections. By law these will be 32 volts.Commonly they are often a tab and socket connection as found in automotive application. They are to be found usually near where the gun disconnects from the machine .They arel ight gauge wires.
A spray and a crimp will fix them up.
The trigger connection operates the gas solenoid,the wire feed solenoid and deliver welding current to the contact tip.
Just the act of moving the gun cable could loosen the connections if they are not stable.
The light that the machine shows is just that -normally a power on/off indicator.If it does not not work and the rest does it simple isn't it. The light is blown.
4th Jun 2007, 10:19 PM #12New Member
- nsw
- 1
doa migs
hey men new to the forum it sounds like you got your problems sorted.
anyhows thought i might post a bit of a yarn Im a trade qualified welder and a few years ago i bought a WIA 215s remote wire feeder mig (GMAW) brand new,suffering from new boys toy syndrome brought her home set it up and guess what no wire feed panicked k,ss of cash (hey i was still an apprentice) and its a dud.
Anyway it turns out that thats the first mig ive still seen to this day that when you turn the wire speed right back to zero thats what you get nil wire feed all the transmig 400 and migomag 400,s we had at work still fed super slow.
the point of this yarn is sometimes it pays to check controls before you pull the side off and start checking connections or break all blokes rules LOL and READ THE MANUAL.
Great Forum lots of switched on men cheers bushboily
4th Jun 2007, 10:29 PM #13
FWIW, the welder kicked to life and was fine afterall. Not sure what the problem was in the end. It just wouldnt feed there for the first few tries
WantedToolex mig welder instruction book
By johncee1945 in forum METALWORK GENERALReplies: 8Last Post: 28th Oct 2008, 06:22 PM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM -
MIG welder drama
By Andy Mac in forum WELDINGReplies: 1Last Post: 6th Mar 2006, 08:28 AM -
MIG welder.. Should I get one ?
By Paddy in forum WELDINGReplies: 12Last Post: 8th Dec 2005, 10:26 PM
