Results 1 to 13 of 13
31st Mar 2007, 09:08 PM #1
Lincoln inverter 160 amp tig arc welder
There is one of these on Ebay that I'm thinking about?
Lincoln electric inverter 160 amp tig arc welder
Has anyone experienced these? Should I buy it Grahame?
We may be moving to a place where there is no three-phase so I may have to sell my welders.
31st Mar 2007, 09:14 PM #2
That sounds like the same as what I've got, mind you there are a few different options on the that model. Great little machine, plenty of punch when stick welding and tig is a joy to use
DJ
ADMIN
31st Mar 2007, 09:56 PM #3
Lincoln has the brand name and the back up, spareparts ,etc
I don't know much about the specific machine.
A way of finding out of any potential problems is to Google up the name ( Lincoln inverter etc ) and the word problems.
It might turn up something.
Its probably unlikely though as Lincoln generally makes good stuff. I have seen machines that are as old as me and still running well.
does that help
31st Mar 2007, 10:05 PM #4
Thanks for that. It all sounds pretty positive. A TIG and a stick welder might just suit me these days. I've gone off MIG a little. Mainly because it never feels like I'm gaining proper penetration. This is probably more to do with my ability than the welder, but still.
1st Apr 2007, 12:19 AM #5
1st Apr 2007, 09:03 AM #6
1st Apr 2007, 12:24 PM #7
1st Apr 2007, 12:47 PM #8
Stuff i forgot
Hey Ross,
Something came to mind after I hit the send button last time.
That was to mention the ability of the inverter systems to weld at very low amps yet give a soft start. Your machine likely has stick ability as well as Tig ,so the following would apply.
An example of this would be when welding with a choke stick welder, say trying to tack two pieces of 3mm wire together.
A touch of the stick on the pieces to be joined virtually explodes the metal,leaving a gap between the two pieces.
Same materials with the inverter at low amps gives a soft start and perfect join. Also something I note that is much different from my old stick welder are tacks that wet ( fuse smoothly into the base metal) with out any observable undercuts .
As an old dinosauar from the stick transformer era I have observed quite different capabilities from these machines. My guess is that you will too.
1st Apr 2007, 07:32 PM #9
I'll buy it if others don't take me into a bidding war. My favourite type of welding is TIG. Mainly because it's quiet and slow, penetration is good, you feel like you have control over the work, and when you lift the welding helmet the weld is closer to what you imagined it might be.
MIG welding rushes me. It lays on metal faster than I can control the weld, if you know what I mean.
Stick welding is good, and I have a beautiful old EMF 300 amp machine that everyone in the neighbourhood likes to use. But as we all know, you need a MIG or a TIG for small stuff.
1st Apr 2007, 07:39 PM #10
1st Apr 2007, 10:11 PM #11Senior Member
- Oct 2003
- Sydney,Australia
- 174
That's - 'Doesn't have a shed YET'.
5 acres and 'Gold Coast' ?- that must be up the back a way, no dodgy landfill.
2nd Apr 2007, 07:13 PM #12
3rd Apr 2007, 04:12 PM #13
I didn't buy the welder after all. I did some last minute research due to pre-purchase buyer's remorse, and discovered that while the seller had listed it as a 160 amp welder, the image indicated a 140 amp model. I think most will agree that the difference between a 140 amp welder and a 160 amp welder is more than just 20 amps. 160 is just enough grunt to start doing some heavy stuff.
I believe it was an honest mistake on the seller's part. I sent him an email as soon as I noticed the difference and he withdrew the welder from sale immediately.
GMAW Welding For The DIYer
By Grahame Collins in forum WELDINGReplies: 8Last Post: 21st Dec 2005, 03:53 PM -
Add a fan to an arc welder
By Stirfie in forum WELDINGReplies: 8Last Post: 12th Sep 2005, 11:09 PM
