Results 1 to 9 of 9
Thread: Mig Wire Question
18th Mar 2007, 05:11 PM #1Member
- Dec 2006
- Sunshine Coast
- 95
Mig Wire Question
I have a large roll of wire which has been sitting around without use for so long it has got a bit of surface corrosion on it. Since I don't currently have a gas bottle due to the rather costly hire charges, I can't try it out.
For future reference, does the corrosion mean it is a throw away reel or can it still be used - i tried a search but came up with nothing
Cheers, Ned
18th Mar 2007, 06:41 PM #2
Iron Bark
I think it would cause some problems in the wire tube. You maybe able to unwind some and it may not be rusty further in the roll.Regards Bazza
Skype Username: bazzabushy
"Experience is a hard teacher because she gives the test first, the lesson afterwards."
-Vernon Sanders Law
The views expressed by the poster are general in nature and any advice should be taken in this vein. The poster accepts no responsibility if this advice is used. When undertaking any work personal professional advice should be sought from suitably qualified persons in the field of work being undertaken.
18th Mar 2007, 07:35 PM #3Golden Member
- Jun 2005
- Helensburgh
- 618
Corroded wire will wreck the liner then you will have to buy a liner as well. If it is a a large roll you may be able to unwind it to find good wire underneath.
CHRIS
18th Mar 2007, 07:50 PM #4Member
- Dec 2006
- Sunshine Coast
- 95
Thanks Bazza and Chris - I will unwind it and it and see what I have got - the reason for my question was actually whether the oxidisation would affect the quality of the weld - I must admit I hadn't considered the feed factors - your input much appreciated
Ned
18th Mar 2007, 07:54 PM #5
With care
G' day Iron bark
As per the other respondents plus this.
When unrolling the layers of wire make sure there is a tension on the spool. Most migs have a spring loading assembly that bears on the spool spindle thus stopping over roll.
if the spool over rolls much more wire than you want or need to can and will come off the spool.
Also if the wire is not to be used for a while bag it up in a garbo bag or the like and chuck in some dessicant.I use the stuff that comes with my blood pressure tabs.That way you will avoid rust. Every Xmas holiday break I bag the mig wire at school in the wels shop, so that the spool wire don,t rust.
another handy hint from
18th Mar 2007, 09:33 PM #6Senior Member
- Aug 2005
- 185
Hate to admit to it, but Ive welded with corroded wire before. It works fine but does leave inclusions in the job, if its not structural not really a big deal. If your running a teflon liner then its still fine won t harm your machine, if your running a steel liner its not that great for it. I find that the best way to store a roll of wire is simply leave it fitted and wrap some waxed paper around the roll. Have left a mig with this stuff inplace and forgotten all about it and gone to use it about 2 years later and it still works perfect.
18th Mar 2007, 10:35 PM #7
Rust in the mig liner
One I had forgotten about
Ok you got rust in your liner .Its not the end of the the world.I used to do the following weekly as regular mig machine maintainence when doing xray level work on pipework. This works on the cafe curtain type spiral wound type liner- not the teflon.
Remove the liner from your torch - roll into a diameter that will fit into an open top 20 litre steel drum.
Place enough kerosene in the drum to cover the rolled up liner and swill in around for a minute or two. Empty it out and dispose of it thoughtfully.
In the same drum place enough methylated spirits and swill it around again.
Remove the liner from the drum.
Carefully using an airline nozzle blow the fluid out out of the liner moving from the back of liner to the contact tip end.
Bingo ,one clean liner.
Done on a regular basis it also serves to be able to check the liner for kinks. -heavy thinks dropped on torch cables cause kinks in the liner- makes it harder to weld by causing resistance build up.
hope it helps you
19th Mar 2007, 12:00 PM #8
There are also small scotch brit/steelwool type cleaners that will fit over the wire in the welder and attempt to clean it as it is being fed, as the wire is drawn through the cleaner before it goes into the liner. Another trick that works to keep the wire from rusting while inside the machine, is to put a small cup with a oily rag, inside the machine near the wire spool. Will stop your wire from rusting and wont cause any trouble with the quality of the weld.
It's Ripping Time!!!
19th Mar 2007, 07:08 PM #9New Member
- Jan 2003
- 9
Back in the north of SA, where I started this life, a time honoured method of cleaning the rust from welding wire was to tie a good length to the back of the ute and then do a couple of turns round the paddock with it in tow.
Very usefull for getting the rust off of fencing wire to be used for oxy welding, although it might put a kink or two in the mig wireRebus
Respooling MIG wire
By Andy Mac in forum WELDINGReplies: 17Last Post: 9th Nov 2008, 06:42 PM -
Current set up for your Mig
By Grahame Collins in forum WELDINGReplies: 23Last Post: 7th Jul 2006, 11:29 AM -
Can you use Mig wire for Tig filler?
By Rossluck in forum WELDINGReplies: 6Last Post: 9th Jun 2006, 06:38 PM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM
