Results 1 to 9 of 9
27th Oct 2006, 12:55 PM #1New Member
- Oct 2006
- Victoria
- 1
Is it possible to cut with an arc welder?
Hi- having to cut some shapes out of a stack of corrugated iron.- far too much to do by hand snips and the curves are too sharp for grinding. Is it possible to use an arc to cut the iron, or better to hire an oxy.
I've used an arc a bit many years ago, but haven't ever used an oxy?
Steve:confused:
27th Oct 2006, 01:45 PM #2
Oxy would be much better than arc - especially on thin stuff, but you can get arc rods specific for cutting (exothermic cutting rods). They are very aggressive.
What about a nibbler - fits to your drill and can cut very precise shapes, tight curves etc. Can be bought from bunnies,
and sounds more suitable to your task. You can also get pneumatic ones.
"Clear, Ease Springs"
www.Stu's Shed.com
27th Oct 2006, 02:22 PM #3
I would go with the nibbler.
An arc or oxy would generate to much heat and buckle your sheets. Also depending on what the sheets are made from, the heat from the oxy or arc will make alot of dangerous fumesCheers
DJ
ADMIN
27th Oct 2006, 03:30 PM #4New Member
- Oct 2006
- brisbane
- 1
2 thoughs....
Hi sprices ,if have the amps (160A maby) you could use a gouging electrode. Something like a 2.5mm UTP 85 would do it . As long as its ferrous theres no probs on what material is . It may cause a little distortion and be a little bit rought, but if you alowed for it you may be able to just grind it back .... or a cabon arc but that needs a compressor and the hand piece , the gougers are just electrods and you local welding supply place should have some , just a thought
28th Oct 2006, 05:00 PM #5New Member
- Oct 2006
- Victoria
- 1
thanks
Thanks for the advice - have been thinking of a nibbler or power metal shears as better alternitives too.
28th Oct 2006, 08:24 PM #6
YEH you can cut sheet metal with an arc welder........ .... a mate of mine tried it at one stage. but its realy realy uggly and hot stuff goes everywhere.:eek: :eek:
Tightly button you collar and pour a jug of water down you jocks first :eek: :eek: .
Uise the bigest rod yor welder will take and crank the amps all the way up.
you will be just blowing holes.
realy nasty, not recomended and definitely a fire hasard.
I'm having a good laugh just at the thaught of this bloke trying to shake sparks out of his jocks.
but it does work.
Seriously there has to be an easier way..... its called a plasma cutter.
People are made of meat.
28th Oct 2006, 09:03 PM #7
I've seen the result of Slag down a Boot..................
NOT GOOD!!!!
Actually, heaps of water down the Boot was the best cure.
By the time one has removed their boot,
The damage is done; the Slag has lost its heat to ones FLESH:mad: :mad:
3rd Degree burns, which most often Ulcerate and / or go Septic to some degree
Arc weld [CUTTING] is BS as far as I'm concernedNavvi
28th Oct 2006, 09:44 PM #8
Love this stuff!
A nibbler or a plasma cutter is the definite safe recommendation, but if you really want it done in a hurry, with an aereonautical display of pyrotechnics, soak some 2.5mm rods in water overnight....rack up the amps...and go for it!
Won't be accurate....you will need fire precautions...but it will cut.
Please pretend it wasn't me that posted this....but I've cut 6mm plate in an emergency using this method.
Regards,
I wish I was anonamous! (where's the spell checker??)
30th Oct 2006, 08:46 PM #9New Member
- Oct 2006
- clothiers creek
- 5
yep you can cut with a arc welder but on thin gauge stuff its best to use a nibbler or something because its messy and not very accurate . ive also cut thinck steel when i was in a paddock and run out of oxygen to cut with , so used the arc welder had it at over 200 amps blowing holes ina excavator bucket to weld a patch in . wasnt very neat but got the job done . i had little burn holes everywhere . :eek:
Current set up for your Mig
By Grahame Collins in forum WELDINGReplies: 23Last Post: 7th Jul 2006, 11:29 AM -
GMAW Welding For The DIYer
By Grahame Collins in forum WELDINGReplies: 8Last Post: 21st Dec 2005, 03:53 PM
