Results 1 to 5 of 5
Thread: Inverter for sheet metal?
29th Aug 2006, 04:57 PM #1New Member
- Aug 2006
- 2
Hi i hope someone can answer my question.
i am fairly good at using an arc and mig welder in most situations.
i sometimes need to weld sheet metal on cars, i was wondering if an inverter welder would weld thin sheet metal, the arc welder tends to make it too hot and blow holes.
i cant afford a mig welder and then the extrta for a bottle of gas.
i havent been able to fing this info anywhere.
cheers
29th Aug 2006, 05:07 PM #2
Don't know if it helps but we used an inverter welder to weld 2.0mm gal. It distorts badly though.
You might be better brazing. You could try one of those MAPP gas guns."I don't practice what I preach because I'm not the kind of person I'm preaching to."
29th Aug 2006, 05:29 PM #3
Most panelbeaters use oxy/acetelene for fixing panels. Fine tips and plain wire.
Also you would pay for an inverter welder for what you would pay for a small handy mig.Last edited by Barry_White; 29th Aug 2006 at 05:32 PM. Reason: Added comments
Regards Bazza
Skype Username: bazzabushy
"Experience is a hard teacher because she gives the test first, the lesson afterwards."
-Vernon Sanders Law
The views expressed by the poster are general in nature and any advice should be taken in this vein. The poster accepts no responsibility if this advice is used. When undertaking any work personal professional advice should be sought from suitably qualified persons in the field of work being undertaken.
29th Aug 2006, 07:30 PM #4
A MIG is your only option. OXY in panel beating, other than for shrinking and a few other jobs, is seldome used for actual welding, unless you are talking about from years ago before the availability of affordable MIG welders.The buckle you can get from a few spots with a MIG ( if you're not carefull ) can be bad enough, but put all that heat from an OXY onto a panel and you are in a world of trouble, even more so with the very thin panels of today, rather than something from an FJ Holden or old Chevy. Hope that helps. Go and try and find yourself a 2nd hand mig and a roll of 0.6mm wire.
It's Ripping Time!!!
29th Aug 2006, 08:33 PM #5
Here you go have a look here.
http://cgi.ebay.com.au/SIP-Gasless-M...QQcmdZViewItemRegards Bazza
-Vernon Sanders Law
New Metal Spinning DVD
By metal spinning in forum METALWORK GENERALReplies: 2Last Post: 5th Dec 2008, 11:25 PM -
Metal cuttoff saw or bandsaw ?
By Rebus in forum METALWORK GENERALReplies: 20Last Post: 10th May 2005, 09:26 PM
