Results 1 to 6 of 6
Thread: mig welder
    Apr 2006
    willagee wa (near Freo)
    60
    10
    Default mig welder
    im looking at buyin a gasless mig welder. what brands are there available in aust. cig $495 from bunnies or maybe this one as its made in italy http://cgi.ebay.com.au/NEW-GASLESS-1...QQcmdZViewItem
    any one got any suggestions????
    First On Race Day
    And the first brock trophy goes to...............
    and we got no "2" as well
    A FORD driver.
    ironic isnt it?
    and if ya cant win on ya own merit punt em off!!!
    holden cheater team!!!!!
    Sep 2003
    40
    Buy as good as you can absolutely afford!!! Any good welder will do innershield, you only have to reverse the polarity on the output terminals. But a welder thats annoying to use will have you never wanting to use it ever, and i'd be looking at the current verses duty cycle it is capable of, nothing worse than wanting to weld and having to wait for the welder to cool down while your running out of patience......
    It's Ripping Time!!!
    Oct 2001
    Warwick, QLD
    45
    1,165
    Mick, I presume you mean gasless welding?
    Sep 2003
    40
    YES!, To do gasless mig, you still need to have the arc and puddle shielded from the air, usually done by the gas, but with gasless mig you use a special wire, Innershield, you dont need gas! the wire itself contains a flux of sorts, thats responsible for the shielding.
    Apr 2006
    60
    10
    thanks for the info
    First On Race Day
    A FORD driver.
    ironic isnt it?
    Oct 2004
    Brisbane
    0
    What do you want to weld ??
    Personally that one off ebay I wouldn't buy - it looks cheap and junky, it won't have a propper liner in the hand piece, and you won't have much of pentration when welding steel - you will be limited in what you can build.
    Depending on what you want to do you should go and look at the unimig or cigweld range at trade tools or glenfords or similar.
    I would expect to buy a gas and gassless mig 175 amp.
    When you are starting out it is easier to weld when you have a better unit with a propper liner and gas with 175amp + it will be easier to make the metal stick together
    I have a 3 phase 300amp in the shed for easily sticking steel together and working in the shed,
    However I am going to get a small portable stick for welding fences or posts on the houses etc.
    Tom
  1. MIG welder drama
    By Andy Mac in forum WELDING
    Last Post: 6th Mar 2006, 08:28 AM
  2. Add a fan to an arc welder
    By Stirfie in forum WELDING
    Last Post: 12th Sep 2005, 11:09 PM
  3. OT: Welder Help
    By Jock_Jock in forum METALWORK GENERAL
    Last Post: 22nd Sep 2004, 08:25 AM
