Results 1 to 5 of 5
Thread: welding tip
7th Jul 2006, 08:03 AM #1Novice
- Dec 2005
- geelong
- 12
welding tip
Hi. this may seem like a stupid question but when welding aluminium should you weld away from yourself or towards yourself. In other words should you push the hand peice into the new weld as you go or sort of drag it away? Thanks for you advise in advance.
7th Jul 2006, 08:15 AM #2
Mako
I presume that you are Mig welding the aluminium.
With Mig you push the handpiece in the direction that you are going to weldHave a nice day - Cheers
7th Jul 2006, 08:21 AM #3
Have a look here for some good tips about welding aluminium
http://www.lincolnelectric.com/knowl...ntent/alum.asp
And this site is great for general MIG tips
http://www.mig-welding.co.uk/index.php?Have a nice day - Cheers
7th Jul 2006, 11:38 AM #4
This is always a point of contention, push, pull, drag etc, angle of hand piece, blah blah blah..... If you look at a dedicated machine set up for process welding you will most likely find that the welding handpiece is set up at 90 deg's or sometimes even set up to an optimium angle. At the end of the day the angle of attack will be goverened by what you are welding and how you can get to it, but what is more a consideration is actually seeing your weld puddle rather than worrying about where you have the handpiece, so that you can SEE that you are making a good weld.
It's Ripping Time!!!
7th Jul 2006, 04:59 PM #5
Push or Pull
Another theory advanced in the text was to push the GMAW torch because of the ( unseen ) swirl in the gas cover creating a vortex that dragged in atmospheric air and resulted in porosity faults.
Having spent a few years dragging a GMAW torch placing vertical down root runs in high pressure radigraphed pipework,I suspect that statement is a load of crap. Where the proplems arise with gas cover vortex and contamination are from uneven spatter build up around the torch gas shroud (nozzle) opening. Problems always occurred if I got lazy and failed to clean and check the gun and the nozzle before starting a run or from failing gas o rings or seals.
Flux core is where the gun is only dragged.I believe the reason for that is so not to weld over the flux and risk a porosity.
Current set up for your Mig
By Grahame Collins in forum WELDINGReplies: 23Last Post: 7th Jul 2006, 11:29 AM -
General welding safety for DIY welders
By Grahame Collins in forum WELDINGReplies: 13Last Post: 15th Jun 2006, 02:10 PM -
Welding
By Twodogs in forum METALWORK GENERALReplies: 4Last Post: 17th May 2006, 12:16 AM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM -
Cast iron welding rods.
By JDarvall in forum WELDINGReplies: 11Last Post: 12th May 2005, 01:08 AM
