Results 1 to 7 of 7
2nd Apr 2006, 10:57 PM #1New Member
- Mar 2006
- 2
Can I use Argon instead of Argoshield
Hi
This my 1st post so be gentle with me.
I currently rent 2 oxy bottles and 1 Argoshield bottle. Ive bought an inverter welder with a TIG attachment and cant wait to have a go with it.
I really dont want to rent another bottle from BOC, they get enough of my money. My question is, can I use Argoshield with the TIG or can I use Argon with the MIG? If I could, this would mean I would only need one bottle for the two machines.
Regards Steve
3rd Apr 2006, 08:46 AM #2
Hi Steve
Welcome to the mob.
The quick answer is yes and no.
Aluminium------------Argon
Stainless steel -------Argoshield Mix
Steel ----------------Argon on a Mig ------------Argoshield mix
Part of the problem with ther cost is those "bottles" you ,make reference to.
They are 10mm thick wall high tensile steel designed tocontain the very high stored gas pressure, in the area where is supposed to be. We are talking 2500 psi or 17,500 Kpa. End Users fail to appreciate the amount of inspection and maintainence that goes into the life cycle of cylinders.
Much of the gas we use is sucked from the atmosphere ,compressed and split up into the various gases we are familiar with.The plants that can do this are expensive and therefore there are not generally widely located.Transport costs to and from these plants add to your maintainence costs.
regards
4th Apr 2006, 12:40 AM #3China
- Dec 2005
- South Australia
- 1,656
Much cheaper in the states you can purchase cylinders and have them refilled. Companies overhere see us all comming
6th Apr 2006, 09:16 AM #4New Member
- Mar 2006
- 2
Hi
Thanks for the replies, I appreciate what BOC do to keep me safe with testing etc of the cylinders etc. I spoke to BOC and the guy suggested that I save up all my TIG welding for 1 month, do monthly rental and do all my welding at once.
13th Apr 2006, 04:30 PM #5Novice
- Apr 2006
- Newcastle
- 10
Originally Posted by Grahame Collins
I currently have Argoshield in use on my MIG.I am going to borrow a friends TIG to repair some Stainless Steel motorcycle mufflers,he tells me that his Argon bottle is empty.
Question is...Can I run the TIG with my Argoshield mix and still get a good result,the stainless mufflers are 1.5mm walled.
Looking forward to your reply
Thank You.
13th Apr 2006, 10:04 PM #6
Grahame may have extra info, but i'd be using nothing other than straight Argon and also back shielding, stainless is fussy stuff and can be even worse depending on the grade.
It's Ripping Time!!!
14th Apr 2006, 10:54 AM #7Novice
- Feb 2005
- sydney
- 20
Originally Posted by stevew
By the same token you do not use pure Argon to weld steel with the mig process, it leaves a very "cold" looking weld that lacks penetration. Use pure Argon in mig for Aluminium only
MIG ARGON or CO2??
By ptrott in forum WELDINGReplies: 9Last Post: 18th Jun 2009, 09:19 PM
