Results 1 to 2 of 2
Thread: MIG welder drama
5th Mar 2006, 11:26 PM #1Andy Mac Guest
MIG welder drama
Hi there,
Just had a funny thing going on with my MIG welder, and have to share it, with some laborious troubleshooting. Its a wee 175 WIA about 3 yrs old, and has proved to be a pretty good unit so far. I got into the shed late last night with a quick welding job set up earlier in the day, turned it on and nothing...no sound, but no light 'cos there isn't one, so turned it off quick. Try again, naught. Checked the powerpoint with another tool before setting to the welder itself, gas bottle off and many screws later I tested the power lead in with a multimeter to make sure some crushed insulation wasn't the problem. I then turned it on and realised the wire was feeding, so power was going through, but no telltale cooling fan! No fuse or overload to be found...so tried turning the fan, and it was stiff to turn. So I undid the fan body from the frame and its guard...turned it on and the fan worked as per usual!! Nothing too wrong, but something stalling the fan. I checked the circular guard, and sure enough, it was stoved in, but mildly...just enough to contact the fan blades. Simple fix and put it all back together, so after an hour delay I was up and welding happily till 12.30....but why did it happen?
The stupid bleeding fan is situated at the base of the machine, facing rearwards...right where the base of the bottle sits, in line with the loading of a new bottle. I'd recently shipped the machine twice onto truck etc so the bottle was being handled frequently, and accidents happen. I guess I did it by rough handling, but pretty peeved that the flimsy guard was simply a lightweight web of wire no more than 1.8mm thick. A dent or distortion, by a 20kg(?) bottle, of about 10mm in a critical area and the cooling system shuts down, risking the life of the welder.
Glad I didn't have earplugs in!:eek:
6th Mar 2006, 08:28 AM #2
Mig Fault
Hi Andy,
I have said before and will say it agin.Migs are reliable machines save for their mechanical bits of which there are lots.98% of breakdowns are mechanical.
I am very surprised that the WIA of which I have spoken of in glowing terms have gone down the road of making their equipment lighter thinner weaker etc.
Twenty years ago the kids at Tafe treated the WIA's like they were someone else's gear and gave them a hard time .They always stood up to the test.
I;ll still stick to what I have said in the past.I said when you buy a machine and it does not matter what brand it is, make sure it is from a major manufacturer and you will never be sorry and not able to get the necessary parts when needed.
My two bob's worth
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM -
MIG for beginer
By Gaza in forum WELDINGReplies: 9Last Post: 19th Feb 2006, 07:11 PM -
MIG welder.. Should I get one ?
By Paddy in forum WELDINGReplies: 12Last Post: 8th Dec 2005, 10:26 PM -
MIG welder - should I HIRE one?
By graemet in forum WELDINGReplies: 4Last Post: 8th Dec 2005, 04:42 PM
