Results 16 to 20 of 20
Thread: Brazing Torch?
17th May 2019, 11:48 PM #16Senior Member
- Oct 2015
- melbourne
- 473
18th May 2019, 09:46 PM #17Most Valued Member
Hi Ken,
for small jobs this silver solder is fantastic. Flows like water and is very strong. A little goes a long way. Too expensive for large jobs though.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And this flux:
Free postage for you too!Chris
21st May 2019, 05:16 PM #18Most Valued Member
- 2,671
For a brazing hearth I'm using some aerated concrete blocks (ie Hebel brick) from Bunnings.
They are light and easy to cut with a hand saw if need be.
Definitely helps make the most of keeping the available heat in the job, but I agree the Bernzomatic torches aren't really up to regular brazing anything of size. OK for up to maybe 15mm diameter. They work fine for the high silver content rod when silver soldering carbide inserts etc.
Best campfire starter ever though!!
21st May 2019, 07:58 PM #19Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Hello OxxandBert,
Did you need to do anything fancy to silver solder the carbide inserts ie special flux ?
A neighbour gave me a big heap of old inserts and was wondering about diy boring bar and diy tool holders.
I saw one youtube video where the chap deliberately fouled the carbide with pencil lead so that the silver solder didnt stick to the carbide, but it did make a perfectly moulded tight fitting pocket.
Xynudu has one video where he smashes old carbide bits with a hammer and uses the fragments to make boring bars.
Bill
I use the Hebel bricks too, seem to work fine.
21st May 2019, 08:02 PM #20Most Valued Member
- 2,671
UPDATE brazing torch cylinders
By eskimo in forum METALWORK GENERALReplies: 10Last Post: 7th Mar 2012, 05:33 PM -
Arc brazing
By verm in forum WELDINGReplies: 7Last Post: 10th Mar 2010, 06:35 AM -
Brazing
By garym in forum METALWORK GENERALReplies: 34Last Post: 9th Aug 2007, 12:12 AM -
Help with brazing with MAP
By BobL in forum METALWORK GENERALReplies: 2Last Post: 5th Nov 2006, 03:28 PM -
Brazing with a TIG
By Rossluck in forum METALWORK GENERALReplies: 3Last Post: 11th Sep 2006, 08:23 PM
