Results 16 to 21 of 21
7th Feb 2019, 10:33 PM #16
Yes would be handy to know!
8th Feb 2019, 11:59 AM #17Novice
- Feb 2019
- Canberra
- 56
- 10
Hi Harry,
The sequence is
Turn welder off
Press arrow next to T2/T2 turn machines on with the pressed
Turn knob under the screen that says P1 on it
Turn to P3 is on the screen
Adjust the dial on the other screen to increase or decrease burn back
Mine was factory set to 3, on 0 is is perfect.
8th Feb 2019, 12:00 PM #18Novice
- Feb 2019
- Canberra
- 56
- 10
Yes but it isn't, not sure why, I did post the sequence in a reply to Harry72. Even though it is in the manual I can't fault the Unimig support staff they are excellent.
9th Feb 2019, 04:46 AM #19
Awesome thanks PennyN, might come in handy one day... I wonder what else they have in the hidden menus
10th Feb 2019, 06:30 PM #20
Next minute, a MWF user drops the revelation about the secret menu to turn a unimig 205 into 1.21 Jiggawatt unit.
People seem surprised, but the days of a welder being a transformer and a few taps for different voltage steps are over. The basic 'synergic' machines have a heap of built in smarts which, 9 times out of ten, prevent the operator from even having to think about burn back. If that's not surprising, then consider the high end units which can now be networked together so that management can interrogate you arc-on time, wire used, gas flow rates, etc... and feed it all back into their quality control systems, or the firing decisions if the operator's defects are too high, or productivity too low.
Big brother, huh?
10th Feb 2019, 08:44 PM #21
Programmable chips in mig welders go back a ways.
In 1986 I was part of a team of pressure pipe welders who trialed a WIA Synergic Gmaw welder for our company. It was the same model said to be developed to weld up Alan Bond racing yacht that won the Americas cup. This was when WIA still made welders in Oz.
Our intended application was for specialised nickel welding on High pressure nickel lined pipe. Every circumferential butt weld was subject to radiographic examination.
They programmed chips were a flop at the time as WIA wqs not able set up a chip to cater for the nickel to our standards.
The damn chips are everywhere now. I saw led flouro batten that a local sparky had.No ballast unit just a chip,some wire connectors and a tube.
UNIMIG razor 200 ac/dc tig welder
By Grahamross in forum WELDINGReplies: 15Last Post: 30th May 2022, 12:49 PM -
Welder near Glen Iris Vic who can weld triton power saw housing back together?
By barrysumpter in forum WELDINGReplies: 1Last Post: 11th Jan 2017, 03:59 PM -
Viper 182 Unimig Any feed back ?
By getsquigs in forum WELDINGReplies: 3Last Post: 23rd Apr 2016, 09:54 PM -
How do you adjust a tailstock?
By Vernonv in forum METALWORK GENERALReplies: 8Last Post: 13th Sep 2014, 11:32 AM -
Arc burn with DC?
By Mathuranatha in forum WELDINGReplies: 4Last Post: 12th Jul 2010, 10:43 PM
