Results 1 to 15 of 17
Thread: Mig welder recommendations
24th Nov 2018, 09:08 PM #1Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
I’m considering getting a new mig in the next few months. 200-250 amps. Doesn’t matter if it is single or 3 phase. Budget is up to $2500. Just wondering what everyone is running? And if anyone can recommend something that is good?
I’m sick of buying 2nd hand welders that die after 6 months.
24th Nov 2018, 09:38 PM #2
Hi Snapatap
Token Tools.
Ring him and he will not tell you any BS.
There are a lot of blokes from this forum who have bought from him and not a bad word yet. After sales service is excellent.
He designs the machines and can repair(rarely necessary) what he sells.
He has been around for about 15 years and is a brick and mortar business with an online sales arm.
There will be others along shortly who will tell a similar story. No connection other than a very impressed customer.
25th Nov 2018, 01:53 AM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,915
If you have $2500 to spend and access to 3 phase, then you are in a really good position. I'd be looking for a good second hand industrial machine. Token Tools machines aren't bad by all accounts, but they are still a chinese sourced machine and are expensive compared to other chinese machines. I've known of the good old original WIA fabricators to go for between $500 and $3000. They don't suffer major failures often, usually only a rectifier pops which is easily repaired and not overly expensive and they will outperform and outlast any chinese machine. Another advantage of this path is that you will get a genuine 250A+ machine with a usable duty cycle as opposed to a 250A output with restricted duty cycle.
Industrial welders are very repairable and in your position, I would pick them over a chinese machine every time.
In thinking about it, you could almost get into an acceptable brand new 3 phase mig for your $2500, however you would need to be careful as some name brand machines at this end of the scale are not all they are cracked up to be. My vote still goes to a solid industrial machine second hand.
25th Nov 2018, 03:59 PM #4Diamond Member
- Aug 2006
- 1,106
As Karl said, WIA fabricator, the older the better in my opinion. I've only used the 400A version and that had the ability to weld all day non stop if need be.
Though if I had that much to spend on a second hand 3 phase based machine these days i'd be looking at a pulse mig. Though if you plan to only weld steel then stick to the WIA.
25th Nov 2018, 04:58 PM #5Most Valued Member
- Sep 2010
- Lebrina
- 1,915
25th Nov 2018, 07:09 PM #6Most Valued Member
I've a CIG 250 amp single phase with an 8m remote wire feeder, and a 4 metre torch, the best thing I ever did. No more having to lift a welder to get into place.
WESS (Welding Equipment Sales and Service) down Lonsdale way can service and supply any of the better brands of machines, should they ever need service.
Have been dealing with them for about 40 years, no connection apart from an extremely satisfied customer.
They were Hills Welding Supplies at Braund rd Prospect, then move to South Tce Wingfield, later to their current location, when the 2 brothers sold to WESS.
Just had a quick look on Gumtree 5 3phase MIGs all under $1,000.
25th Nov 2018, 09:32 PM #7Diamond Member
- Jun 2010
- Canberra
- 1,322
I've been thinking about a bigger MIG machine - I've been running my humble UniMig 165 at full noise on a few heavier jobs, and while it lays down nice (and quiet) spray transfer welds, the torch clearly can't handle the heat, with the bit behind the nozzle starting to melt.
I was tossing up getting a machine with pulse, have steel wire in the machine and a spool gun set up with aluminium, meaning I'd only need to change gas and plug in the spool gun to weld aluminium, no messing around with changing liners. Tokentools seemed the best bet.
Then I spotted a 3ph Migomag 400 on Gumtree for $1,100 which would certainly take care of heavier section welds, but it's a big machine, which could pose a challenge finding shed space for it...
25th Nov 2018, 11:44 PM #8Most Valued Member
MigOMag are a good welder, had a few over the years. Sold with businesses, not failures.
27th Nov 2018, 07:53 PM #9Most Valued Member
- Sep 2010
- Lebrina
- 1,915
IMHO Migomag are quite under rated, definitely not the rolls royce of welders, but they are good solid performers that will do 99% of anything anyone may want. I've got an old Migomag 300 that can still hold it's own against the newcomers. Transmig 500's (the old ones, not the new ones which are crappy), go quite cheaply too and are a lot of machine for the money, albeit in a bulky package.
27th Nov 2018, 08:15 PM #10Diamond Member
- Aug 2006
- 1,106
Yeah those old grey cigwelds are built like a tank, even the old school 350 Pulse wasn't a bad machine.
27th Nov 2018, 09:53 PM #11Philomath in training
If you go here https://wess.com.au/our-products/second-hand/ you may see something that suits (filter for used). There is a WIA fabricator there for example
As Wess are probably the premier welding equipment place in SA and do repairs, I would expect that any secondhand gear they sell would be up to the mark.
28th Nov 2018, 10:01 AM #12Most Valued Member
- Sep 2010
- Lebrina
- 1,915
28th Nov 2018, 12:23 PM #13Diamond Member
- Aug 2006
- 1,106
I thought it had similar chartistics to the Panasonic.
Have you used a S3-C before? If so what did you think of it? Was given one years ago but no 3 phase at the moment so it sits unused.
29th Nov 2018, 02:28 PM #14Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I have indeed. They run Aluminium quite nicely and the one we had also spent a bit of time running Stainless. I particularly liked it when running ally on sub 5mm thicknesses as it seemed to run a little nicer than even the Fabricator we had. You often see them for sale for peanuts and if I needed another welder, I would have no hesitation in snaffling one.
29th Nov 2018, 09:12 PM #15Diamond Member
- Aug 2006
- 1,106
Might hang on to this one then, doesn't take up a lot of space.
End Mill Recommendations
By 19brendan81 in forum METALWORK GENERALReplies: 5Last Post: 17th Aug 2018, 07:14 PM -
Recommendations for Small Stick Welder
By foccacia in forum WELDINGReplies: 53Last Post: 28th Apr 2012, 09:31 AM -
Inverter Arc / Stick welder recommendations
By Matty5700 in forum WELDINGReplies: 10Last Post: 17th May 2009, 10:53 AM -
4 jaw chuck recommendations
By snowyskiesau in forum METALWORK GENERALReplies: 39Last Post: 7th Oct 2008, 06:11 PM -
RHS tube bender.... any recommendations ?
By Fossil in forum METALWORK GENERALReplies: 9Last Post: 22nd Jan 2008, 12:19 PM
