Results 1 to 7 of 7
Thread: Another Welding table
18th Sep 2018, 01:52 AM #1Senior Member
- Perth, Western Australia
- 67
- 362
Well after about 8 years I thought it was about time to do some of the things I had planned to do when I first build the table.
First step, holes, and lots of them.
Over the years had drilled and tappet a few holes to hold things down but there was no way I was going to do a 120+ holes through 1” plate freehand.
So one of the heads from my body roller, some RHS offcuts, linearthruster, mount plate a drill and we have some holes.
After drilling a dozen holes thoughts turned to tapping the holes.
I did not want to mount the tapping head to the ally thruster for fear of bending it so I pinched an idea from the net and built a parallel arm. I then mounted a hydraulic motor to that, machined an adaptor for the tap and now we have some tappet holes.
Adapted the drill head to the parallel arm and drilled some more holes.
As I am a lazy basted and found it too hard to push and pull the lever on the control valve to rotate the tap I set up a pneumatic control valve so I only had to flick a switch.
Had to move the setup around the table a few times and make a couple of other mod`s but eventually it is all done.
Tony
18th Sep 2018, 02:08 AM #2Senior Member
- 67
- 362
The addons begin.
Slide out table for plasma cutting.
Adapted the pneumatic vice I built awhile ago. Very handy when sanding of bits and pieces.
Tony
18th Sep 2018, 04:12 PM #3Senior Member
- 67
- 362
It`s like a kid with a new toy.
There was no need to clamp this job down it`s only some 20x20mm rhs, but hey got to test the holes are working properly.DSC05757 e.jpg
18th Sep 2018, 06:50 PM #4Diamond Member
- Aug 2006
- 1,106
Nice work bench, I've always liked the idea of having a perfectly flat plate with holes everywhere that are perfectly aligned with each other. Makes setup and clamping easy.
Also looking through your photos, I noticed you have a 2 button pneumatic pendant. Could you advice where you got this from, would be a handy thing to have.
18th Sep 2018, 11:05 PM #5Senior Member
- 67
- 362
perfectly flat or perfectly aligned this table is not, but its nice to be able to clamp things down instead putting tack welds everywhere then cleaning them up.
The two button pendants are handy but where to get them without going to someone like Enerpac or Power Team I`m not sure. From memory they were not cheap. Luckily the few I have fell into the back of my ute instead of the scrap bin when the pumps were scraped.
I have mounted small button valves on a piece of shaped ally plate that worked well.
Tony
19th Sep 2018, 10:45 AM #6Diamond Member
- Aug 2006
- 1,106
Yeah didn't think they would be cheap. What are those button valves from, might have to make something up.
19th Sep 2018, 04:13 PM #7Senior Member
- 67
- 362
The button valves are an off the shelf item. Any pneumatic supply company should have them.
This one is a Mindman TAC MVHA-3P.
Welding table
By node105 in forum WELDINGReplies: 7Last Post: 18th Aug 2018, 10:58 PM -
Welding Table top
By eskimo in forum WELDINGReplies: 19Last Post: 17th Mar 2018, 03:59 PM -
FixturePoint Welding Table 900 x 600mm Table
By dradyz in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th May 2016, 01:38 PM -
Topping a welding table
By th62 in forum METALWORK GENERALReplies: 11Last Post: 18th Aug 2014, 11:22 AM -
Folding Welding Table
By bimbo in forum WELDINGReplies: 16Last Post: 2nd Jun 2012, 05:31 AM
