Results 1 to 5 of 5
    Jul 2010
    Brisbane
    143
    Default Cheap alum welding
    Hi.
    does anyone know who does cheap aluminium welding in the Brisbane region ?
    Ken
    Dec 2005
    South Australia
    1,658
    I don't know about Brisbane, in Adelaide there is no such thing as cheap Aluminium welding
    Apr 2013
    Toowoomba Qld
    401
    What are you wanting welded ?
    Will be chasing a different grade of aluminium welder depending on the job. Is it a simple one that any hack with a AC/DC Tig could weld up or is it something critical ?
    Jul 2010
    Brisbane
    143
    Quote Originally Posted by MasterSpoon View Post
    An aluminium casting of an old wood lathe.. made a new piece to fit.. the filler piece is not cast, not sure if this is a problem ?
    Ken.
    Sep 2010
    Lebrina
    1,915
    Quote Originally Posted by kenny_10 View Post
    Ken.
    You may find difficulty finding someone to take the job on as repair jobs like this can be very hard to charge for, (they can easily eat hours due to welding difficulties caused by contamination, parent material type or cracking upon cooling). Having said that it shouldn't be impossible. I would suggest that you ask yourself what the consequences are should the component fail in service. If it is simply a guard or cover, then little of a negative nature may occur, but if it is a structural component, you may be in the firing line. Aluminium forgings do not repair overly well however and their strength is much less than original.
    The replacement piece being of different type shouldn't present too many difficulties and any reasonably competent welder should be able to effect the repair.
  1. Replies: 4
    Last Post: 15th Jun 2016, 01:32 PM
  2. Welder to mig steel and alum
    By KWD in forum WELDING
    Last Post: 20th Dec 2011, 08:32 PM
  3. Cheap As Chips Welding Gloves
    By matthew_g in forum WELDING
    Last Post: 9th Sep 2010, 11:49 PM
