Results 1 to 8 of 8
28th Aug 2018, 01:09 PM #1Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Budget tig welder: what is the two pin socket?
Hi all,
I am considering this Rossi 3 in 1 tig/arc/plasma:
https://www.edisons.com.au/rossi-tig...achine-ct620is
It can't take a foot control, but I was wondering what the two pin socket on the front is for? Their generic manual has a diagram for another machine and refers to something similar as a 'high frequency start control' - but I don't know if this is the same thing.
All advice welcome. Excuse me if the answer is obvious - I'm not a welder, but I did do a TAFE course some years ago - no tig.
Greg.
28th Aug 2018, 01:20 PM #2Diamond Member
- Aug 2006
- 1,106
I haven't had a look at the link but it is most likely for the on off trigger switch that operates the solenoid.
28th Aug 2018, 01:24 PM #3Golden Member
- Aug 2015
- 843
that might be, say, for an on off switch on the torch?
28th Aug 2018, 02:11 PM #4China
- Dec 2005
- South Australia
- 1,658
May get a more knowledgeable answer in the WELDING SECTION
28th Aug 2018, 03:43 PM #5
It runs to the switch on the Plasma Cutter and Tig Handles.
Shane
Got the square peg in the round hole, now can't get it out !!
28th Aug 2018, 07:34 PM #6Novice
- Apr 2010
- Bundoora, Victoria
- 20
I've got a similar Rossi 3 in 1. It's so easy to use and works well but you will probably want to upgrade the earth clamp and electrode holder. They're not that good.
28th Aug 2018, 11:14 PM #7Golden Member
- Aug 2015
- 843
China, thanks. We've been moved here now. Auskart. Thanks. On that basis I bought one. Adyadad. Cheers. Made from 'chinesium' no doubt. But good tip. This will be my first welder so I am happy you are happy with yours. At $350 on eBay at the moment it is pretty hard to pass up. And with aussie warranty as the eBay shop is edisons.Thanks again. Greg.
19th Jul 2020, 10:18 PM #8New Member
- Jul 2020
- 1
Purchased 2d hand rossi ct620is - cut issues
Hi guys, as one of you guys mentioned lookibg at buying this rossi tig/mma/cut, and someone said they have one. I thought i would try my luck with some help. I purchased one of these off gumtree a year ago or so, tge guy said he barely used it, and it looked like that was true.
Ive used it to stick weld and its all good. But wanted to use the plasma cutter and when i move the switch to cut, the highest it will go up to is 29... 30 flickers on and off but does not get there. Its supposed to be 50amps. Tried switching it on and off a few times. One of the times, the highest ut went up to was 16amps. But next on/off back to max of 30amps.
Would love some help guys
15amp mig welder plug to 10amp wall socket
By Specialized29er in forum ELECTRICALSReplies: 26Last Post: 30th Apr 2018, 12:13 AM -
Wood Cutting bandsaw speed - budget workaround
By steamingbill in forum METALWORK GENERALReplies: 0Last Post: 25th Mar 2016, 02:54 PM -
Budget Crucuble ideas wanted - Aluminium melting
By MWP in forum THE FOUNDRYReplies: 3Last Post: 9th May 2013, 08:01 AM -
$150 budget to get an arc werlder
By Gags_17 in forum METALWORK GENERALReplies: 58Last Post: 12th Apr 2007, 11:26 PM
