Results 1 to 9 of 9
Thread: 3 phase mig for panel work?
5th Aug 2018, 01:49 PM #1Member
- May 2012
- Tasmania
- 50
Greetings
I have picked up an old WIA 300amp 3phase machine which I will use for my heavier fabrication jobs and farm equipment repairs.
I have been told these machines can be better light work machines than small single phase welders as they can go very low and are smoother. Is this correct?
Can you set up the wire feeder for 0.6mm wire? Are these old machines worth spending money on?
I have a Bernard gun and Tweco adaptor or could easily drop a Euro gun on it with a small liner. Might have to make 0.6mm rollers though? The wire feeder is driven by both rollers so maybe that is a plus.
I'm hopeful but sceptical as I don't believe these machines were ever designed for light work.
Thanks in advance Craig
5th Aug 2018, 06:59 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
I don't see why it wouldn't work. With 0.8 wire we have them set mid range at work, so still plenty of adjustment to drop the amps and wire speed. You can run flat rollers with solid wire, so you shouldn't have to make some. That machine is defiantly worth spending money on, all simple and easy to fix controls, unlike the modern machines with control boards worth big $$$$.
5th Aug 2018, 08:48 PM #3Member
- May 2012
- Tasmania
- 50
Thanks snapatap.
Are the WIA machines pretty reliable? They look very robust and well made. I love old Aussie gear, but it saddens me to see our capacity to make our own stuff disappearing.
I hadn't thought to just use flat rollers, I expected a lack of drive. I guess both wheels driving would make a lot of difference.
8th Aug 2018, 12:30 PM #4Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Don't let the old WIA out of your sight! They are a beautiful machine and far better than anything WIA "produce" now - Chinese made in many cases.
Well worth spending a dollar on, although you probably won't need to as not much tends to go wrong and parts are generally generic and available.
It would be in your interest to convert to a EURO fitting if you plan on doing both panel work and heavier work as you can easily swap guns (EURO guns are readily available and cheap) so you could have a small gun setup for panel work and a larger 3 or 400 amp gun for meatier jobs. Only downside to the WIA feeder is that rollers tend to be expensive compared to the newer machines, however, you may be pleasantly surprised at how low you can tune your machine with .9 wire.
8th Aug 2018, 02:08 PM #5Member
- May 2012
- Tasmania
- 50
Thanks Karl. I have machined up a bobbin that fits the Bernard socket and threaded the end to take the M10 Euro adaptor. It all works nicely but I think I will fold up a support bracket as it is a lot to hang off the hollow M10 spindle, especially if you are reefing it from place to place.
I am yet to try it on low settings on panel material as I decided to strip the machine, replace the sockets and all internal hoses and give it a paint and good clean. Should be like new in a weeks time.
15th Aug 2018, 08:05 PM #6Senior Member
- Nov 2011
- 103
WIA are excellent, particularly the Bernard guns (torch), smooth, small trigger action, feel so much more controllable than the Tweco (to me, anyway).
15th Aug 2018, 11:22 PM #7Most Valued Member
- 5,942
If you want to use .6 wire, I'd use a short gun lead, have seen where it creates problems in the lining, particularly if the wire welds itself to the tip. Personally I'd run the .9 wire for all the welding, light to heavy.
16th Aug 2018, 07:37 AM #8
I am with Karl on the WIA comments. The old ones are built like brick dunnies.
The Tafe that I started teaching in had WIA machines.
The apprentices could not break them and they were fairly adept at breaking most things.
Bear in mind that any stoppages in the old style machines were 99% mechanical. There was not much electrical to go wrong and what there was could be readily fixed.
16th Aug 2018, 02:38 PM #9Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Homemade rotary converter 230v single phase to 415v three phase (Video)
By Tilly819 in forum ELECTRICALSReplies: 0Last Post: 27th Jul 2018, 09:12 PM -
What to buy for panel replacement work?
By Peter57 in forum WELDINGReplies: 8Last Post: 18th Jan 2013, 09:00 AM -
240v single phase to 415v 3 phase conversion
By Oldneweng in forum METALWORK GENERALReplies: 81Last Post: 12th Jul 2012, 05:58 PM -
Huanyang VFD - How to get single phase outputs from VFD 3 Phase output points (U,V,W)
By AP-R*D in forum METALWORK GENERALReplies: 14Last Post: 4th May 2012, 08:48 AM -
Hercus 3 phase lathe, single phase supply
By Pete F in forum THE HERCUS AREAReplies: 51Last Post: 16th Jan 2009, 10:15 AM
