Results 1 to 7 of 7
Thread: Safety of Welding Outside
3rd Aug 2018, 08:29 AM #1New Member
- Aug 2018
- Nebraska
- 26
- 3
Hello,
I'm fairly new to welding/metalworking and I'm just about to buy my first MIG welder. Previous experience has mostly been using my gpa's SMAW on the farm.
I live in an apartment and don't have a garage just yet. A good friend of mine has a rental house with a driveway but not covered garage. If I weld using fluxcore in the open in his driveway, is that an issue? I'm concerned about passerby on the (small neighborhood) road getting upset about the arc and making a fuss. I've been around campus where they're welding on a building out in the open without any shielding and didn't seem to have any issues.
Worst case scenario I may be able to place my car in between the road and me welding, but I don't even know if I need to bother with that.
Is it a bad idea to do it in the open without buying a screen?
Thank you, and God bless!
3rd Aug 2018, 04:44 PM #2China
- Dec 2005
- South Australia
- 1,657
This being a Australian based forum ( I am assuming you are in the USA ) it is not possible to give a answer as local regulations may apply, if it was in Australia I would say
it would not be a issue
4th Aug 2018, 12:13 AM #3New Member
- Aug 2018
- Nebraska
- 26
- 3
Ah, didn't realize that this was Australian-based. Thanks for the info. Well I guess we'll just try it and find out then.
4th Aug 2018, 06:09 PM #4Most Valued Member
- Healesville
- 2,129
If you are worried about it can you tie a rope across the driveway and hang a sheet or tarp over it, just don't set fire to it
shed
5th Aug 2018, 12:24 AM #5New Member
- Aug 2018
- Nebraska
- 26
- 3
Good thinking!
5th Aug 2018, 06:06 AM #6Member: Blue and white apron brigade
Using your car as a barrier may not be a good idea as welding sparks can easily travel 4-5 yards and when they land on the car duco can make a permanent mark that lets rapidly to trust.
5th Aug 2018, 06:16 AM #7
The UV radiation generated dissipates very rapidly over distance. There is an OSHUA table somewhere on the net that references this.
From memory, there was also a study by the US Army.
Flash intensity drops with the cube of the distance. So the intensity 10 feet away is 1,000 times less than it is 1 foot away. 20 feet away is 8,000 times less. 30 feet is 27,000 times less.
Once you're 10-15 feet away there's not much issue from a flash as long as the person doesn't sit there and stare at it. If they're 30 feet away there's pretty much no issues even if they do.
VFD safety
By BobL in forum ELECTRICALSReplies: 10Last Post: 5th Sep 2016, 09:40 AM -
Safety tip
By .RC. in forum WELDINGReplies: 2Last Post: 27th Jul 2009, 01:55 PM -
Mig welding Course Lesson 1 Safety
By Grahame Collins in forum WELDINGReplies: 27Last Post: 29th May 2009, 09:04 PM -
General welding safety for DIY welders
By Grahame Collins in forum WELDINGReplies: 13Last Post: 15th Jun 2006, 02:10 PM
