Results 31 to 31 of 31
25th Mar 2018, 10:11 AM #31Member
- Feb 2012
- 67
If you're not proficient on starts & finishes where there's an air gap at each end, you can often tack a small tab at each end on which you can then start & finish, just grind off the tabs after completing the weld. The main weld then looks consistent and even.
If your hand is a bit shaky with a long new electrode, hold near the bottom of the electrode with your (free) gloved left hand to strike, then gradually move that hand up the electrode as it burns down, withdrawing it completely when you feel comfortable and steady.
C02 for Mag Welding
By toyota254 in forum WELDINGReplies: 20Last Post: 13th Jun 2012, 04:56 PM -
Welding gal
By Groggy in forum WELDINGReplies: 6Last Post: 10th May 2009, 11:00 PM -
lets get some activity - your projects
By bollie7 in forum METALWORK GENERALReplies: 59Last Post: 9th Feb 2009, 10:22 PM -
Lets do the time warp again
By Cliff Rogers in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 10Last Post: 22nd Sep 2006, 07:29 PM
