Results 1 to 4 of 4
    Jul 2006
    Athelstone, SA 5076
    4,255
    Default Tig water cooling
    I suspect that all these are is a fan forced coil with a small pump to circulate water.
    Would this be correct?
    If so I have some small coils from scraped aircon units that may suit if some one would like to explore the possibility of making one for themselves
    message me if interested
    Jun 2010
    Canberra
    1,322
    This Old Tony did a good video about modifying a unit he was given, which is a good guide as to how they're put together.
    https://www.youtube.com/watch?v=x2ai5eDzvxU
    The one feature I wouldn't have thought of is the flow alarm, which makes sense, since if the flow stops and you don't realise, the torch could heat up and melt pretty quickly.
    7,183
    Thanks for the link to the vid, Old Tony has a funny way of putting things which adds to the viewing experience.
    Jan 2015
    Sydney
    211
    I made a tig cooler for my tig, holds about 10l, radiator and a thermo fan on a controler to turn on if it gets too hot.
    If i was to do it again, i would make it half the size maybe even less, probably 3l to make it more portable and get a smaller radiator.
    Ive never had the temp rise more then 5 degrees above ambient, even on ac.
    Im even tossing up the idea of making another cooler as the pump im using is quite noisy and vibrates. (12v diaphram pump)
  1. ASEA motor with broken cooling fan
    By paul33 in forum ELECTRICALS
    Last Post: 26th May 2017, 06:41 PM
  2. Mist Cooling / Cutting Lubrication Question ..... ?
    By RoyG in forum METALWORK GENERAL
    Last Post: 9th Jul 2016, 08:28 PM
  3. Cooling down a mini-mill motor
    By Jors in forum METALWORK GENERAL
    Last Post: 15th Jan 2013, 09:10 AM
  4. flood cooling
    By tanii51 in forum METALWORK GENERAL
    Last Post: 5th Mar 2010, 09:18 PM
  5. Cooling while cutting
    Last Post: 7th Mar 2007, 12:42 AM
