Results 1 to 4 of 4
    Oct 2017
    Adelaide South Australia
    9
    Default POL versus CGA510 and Acetylene regulator inlet
    Hi all, new round here.
    I'm in Australia, in case that has any relevance to my question.
    According to many websites, an Acetylene regulator may be used with Propane (LPG) and there are many examples where they have been used to set up an Oxy Propane brazing system using a 'BBQ Gas Cylinder'. But these examples I have seen are mostly from the USA.
    Now the Acetylene regulator uses a CGA510 fitting.
    Here's one which says CGA510 and POL are the same.
    http://www.bestmaterials.com/PDF_Fil...ng-threads.pdf
    But the Acetylene regulator I have does NOT fit the POL output on my LPG (Propane) tank. It is VERY close and also a LH thread - am I missing something?
    Could it be that the Australian version of POL is slightly different, perhaps CGA520 and therefore I would need one of these:
    https://www.amazon.com/CGA-520-Acety.../dp/B06WVJKWP3
    Jun 2005
    Helensburgh
    618
    Playing with the wrong equipment and explosive gases is not good for the mortality of one's life. The regs are not interchangeable for a reason, one of those is if cutting the Acetylene reg won't flow enough gas.
    CHRIS
    Oct 2017
    9
    Agree. Still I'm curious to know if they are same in the USA.
    Dec 2005
    South Australia
    1,658
    LPG will destroy your acetylene regulator you need a regulator specifically designed for LPG
  1. Mig regulator problem
    By morrisman in forum WELDING
    Last Post: 2nd Oct 2016, 11:02 PM
  2. Replies: 6
    Last Post: 1st Jul 2012, 10:25 PM
  3. Replies: 14
    Last Post: 5th Mar 2012, 09:45 PM
  4. Oxy regulator pulsing
    By jack620 in forum WELDING
    Last Post: 26th Aug 2011, 06:15 PM
  5. Regulator for Mig Gas ???
    By Stewart69 in forum WELDING
    Last Post: 4th Jun 2010, 03:31 AM
