Results 1 to 14 of 14
Thread: Aldi inverter welders, any good?
29th Sep 2017, 06:17 PM #1Diamond Member
- N.W.Tasmania
- 1,407
Aldi will have this welder on special on October 7th, https://www.aldi.com.au/en/special-b...lder-140amp-1/and I'm just wondering what the consensus is on its performance and value. Presently my welder is an Arlec 140 ish amp transformer unit, but as I have to use a 70metre extension cord to use it, I have trouble striking an arc, and wonder if an inverter unit may be easier to get going, as well as being much more portable, and if so would this Aldi unit be good buying, or is there better value elsewhere .
29th Sep 2017, 06:52 PM #2Member: Blue and white apron brigade
- 7,182
The so called "high duty cycle" of 15% at its max current (140A) is a good indicator that it is a light duty machine.
To get something that might last look for something that has about 2x more duty cycle at max amps.
Few DIY folks need a high duty cycle machine but it is an indicator of how robustly the machine has been made and hence how long term reliable it will be.
It probably won't like a 70m extension cord any more than your transformer unit.
1st Oct 2017, 12:27 PM #3Golden Member
- Jul 2011
- 837
Aldi accept returns pretty easily. I would get one and give it a go.
1st Oct 2017, 12:36 PM #4Most Valued Member
- Sep 2010
- Lebrina
- 1,910
BobL is dead on the money with his comments. Inverters have inbuilt circuitry that shuts them down in either an over or under voltage condition to prevent damage. While Inverters convert electricity more efficiently than transformer based welders and thus stretch the capabilities of a power supply, there reaches a point where extension leads produce sufficient voltage drop and the inverter shuts down. 70M is a long run and you really need top quality leads to be successful when trying to weld. If this is a regular activity, then I would consider buying 4mm three core flex and making a dedicated lead. Assuming a 70m run and 15A full load current, 4mm cable will meet the <5% voltage drop requirement of AS3000 (just). 6mm would be even better, but I doubt you will fit it into a standard 3 pin plug.
The so called heavy duty leads that hardware stores sell are often only 1.5mm which would produce around 13.5% drop over the same run plus a bit extra for every plug in connection on the run.
1st Oct 2017, 01:34 PM #5Diamond Member
- Jun 2010
- Canberra
- 1,322
I welded a couple of hinges to a gate post for a friend a few weeks back. That was about 160m - we did have one extension lead made from old 3-phase bore pump cable with the conductors doubled up, but at least half of the run was with those cheap stripey 30m extension leads you get from Bunnings. Used 2.5mm rods at around 90A on my BOC 130A inverter - only welded 1" stitches and while the behaviour was a bit weird, it got the job done.
4th Oct 2017, 01:12 PM #6Intermediate Member
- Mole Creek
- 45
Given that your power source is so far away from where you want to use your welder, maybe a generator would be a better investment?
Not sure what size your welder would need, perhaps 3kVA? I'm sure someone else here could advise you on that though.
Cheers,... Jon.
Sent from my Moto G (4) using Tapatalk
4th Oct 2017, 09:20 PM #7Diamond Member
- N.W.Tasmania
- 1,407
Thanks everyone for your contributions, and apologies for my tardy response, but am travelling homeward ATM from the top of the big island, and most times at the end of the day I am pretty knackered and if I do get online, it is usually brief, short and sweet before the cot becons and I toddle off. Although most other options cost at least double, I may leave it and save a bit more for a stick/tig machine. Much more expensive I know, but also giving me altogether new capabilities as well as a likely better performance as a stick machine to boot.
i would still be interested to hear the experiences of anyone who has used an Aldi inverter welder, paticularly if you have used several other inverter welders and can compare their abilities. As BobL suggested I am not likely to be using 140 amps very frequently, but I would lik a machine that doesn't cause me grief when I go to use it. All other things being equal, cheap is good, and yes I know, all other things are hardly ever equal. Thanks again for your comments,
Rob.
5th Oct 2017, 10:45 PM #8Most Valued Member
- Sep 2010
- Lebrina
- 1,910
5th Oct 2017, 11:26 PM #9Intermediate Member
- Mole Creek
- 45
6th Oct 2017, 12:55 PM #10Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
I have a similar stick welder but mine is set up for DC TIG and is a Repco brand absolutely love the little thing weighs bugger all and the machine is tiny, but do keep in mind mine doesn't have high frequency and i was working on a job/hobby trying to weld a nut onto a seized and snapped 6mm bolt on a outboard motor and the scratch start got the better of me i accidentally hit the aluminium block trying to initiate the spark and ate away a small part of the aluminium
so something to think about with the cheaper machines, HF start is like gold on a welder
6th Oct 2017, 01:50 PM #11Intermediate Member
- Mole Creek
- 45
6th Oct 2017, 04:21 PM #12Diamond Member
- N.W.Tasmania
- 1,407
Yep, I know all about that,-a couple of years ago a neighbour was selling up and had a clearing out of odds and ends, and his trailer mounted 350 amp diesel powered welder went for $25! Admittedly it looked a pos,the trailer very rusty, the mudguards almost non existent due to rust, but the welder was in good nick he told me. A bloke I know got it for the motor to power an irrigation pump which afaik has never happened.
6th Oct 2017, 04:30 PM #13Intermediate Member
- Mole Creek
- 45
23rd Mar 2018, 10:26 AM #14
I know it's a bit late but I did buy one of the Aldi inverter welders when they were on special and I love it. Such a handy little light weight welder that's good for quick jobs around the house & farm.
My local Mens Shed also bought a similar "Bossweld" brand inverter welder with similar specs and it's used more often than the older CIG unit. At present we're making a new driveway gate from 50mm Galv pipe and it handles this with ease.
Pat
Large plastic chopping board at ALDI - good plastic stock
By pippin88 in forum METALWORK GENERALReplies: 1Last Post: 3rd Jul 2017, 10:24 PM -
Are Uni Mig Stick Inverter Welders any Good?
By BigPete1 in forum WELDINGReplies: 30Last Post: 19th Dec 2012, 07:39 PM -
Are esab ac/dc tig welders any good
By steran50 in forum WELDINGReplies: 9Last Post: 8th Aug 2012, 08:23 PM -
is it ok to use dc inverter welders with a generator?
By steadyeddie in forum WELDINGReplies: 4Last Post: 22nd Mar 2011, 09:07 PM -
A good site for welders
By Grahame Collins in forum WELDINGReplies: 1Last Post: 30th Jun 2006, 08:16 PM
