Results 16 to 18 of 18
29th Jul 2017, 09:16 PM #16Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Maybe you're right Kryn: I need to go back to basics and sort out my technique. Maybe I will try your suggestion.
But no-one has addressed my basic question: What's the difference with a V joint that messes up my welds? My logic is it's because the slag has nowhere else to go. So I guess I need to move faster, and that means turning up the current, right?
29th Jul 2017, 10:58 PM #17Senior Member
- Jan 2015
- 211
Tight vee grove, the flux on the rod could be getting in the way and causing a long arc? Try to crank the amps up some more.
1st Aug 2017, 11:59 PM #18Novice
- May 2015
- Aus
- 24
I still prefer 7016's for this type of work, and if you're struggling to get a good weld doing it faster with iron powder won't make things better.
Weld hot with a short arc, 60deg v prep. If you are too high and too steep you'll force the slag into the weld - think of the arc as a jet pushing into oily water (hope you get the analogy).
Most of these issues I've seen are from excessive arc length and welding cold (too low current).
You can also increase your back angle a bit to push the slag back more with the force of the arc.
Prep Work for welding Gal Steel
By capt'ngrumpy in forum WELDINGReplies: 9Last Post: 4th Feb 2013, 12:59 AM -
Having trouble welding a T joint
By SimonP in forum WELDINGReplies: 16Last Post: 28th May 2012, 08:52 PM -
old stick welding m/c
By gpigeon in forum WELDINGReplies: 24Last Post: 27th Mar 2012, 07:06 AM -
Mug stick welding 8mm steel rod
By Scally in forum WELDINGReplies: 9Last Post: 12th Jul 2008, 11:23 PM -
Stick Welding
By Grahame Collins in forum WELDINGReplies: 51Last Post: 17th Sep 2007, 11:10 AM
