Results 1 to 15 of 18
22nd Jul 2017, 07:56 PM #1
Need help with bench top and clamps
I'm building a general use fabrication/welding bench.
Attachment 368870
The top consists of 6 X 250PFC, these aren't fixed in place yet. I can't think my way through to what type of clamping system to use so I'm not sure what spacings too make the PFC. There's 1800mm overall to work within which leaves an absolute max spacing of 60mm.
This bench will not have a single use so I'm looking at options.
Do I just use standard G clamps or make ones to run in the slots?
Brains trust, what would you do?
22nd Jul 2017, 08:23 PM #2Most Valued Member
Sorry to say this but your attachment doesn't work, it comes up with the message, Invalid Attachment specified. If you followed a valid link, please notify the administrator.
What is the 6 X 250 PFC, it's a term I've not come across before? I found that no matter where the positions are suitable for a clamp, it won't be suitable to clamp the project on the bench.
22nd Jul 2017, 08:27 PM #3
Any ideas on how to get the photo showing? It was there in preview before I posted.
22nd Jul 2017, 08:33 PM #4
@KB, 250mm Parallel Flange Chanenel. With the pic it will be self explanatory, I hope. Or once I know how can post more pics.
22nd Jul 2017, 08:39 PM #5
Not sure what's going on with the pic? When I press "edit post" the pic is there, maybe doesn't like my haircut?
22nd Jul 2017, 08:56 PM #6Most Valued Member
- 70
- 1,514
Six lengths of Parallel Flange Channel with a spacing of 60mm between each to make a bench top is what he has.
Nev.
22nd Jul 2017, 09:15 PM #7
Does this help you?
22nd Jul 2017, 10:35 PM #8
Yeh Grahame, that's the line of thinking I'm on. What spacing between the PFC to make clamps like that?
22nd Jul 2017, 10:38 PM #9Philomath in training
22nd Jul 2017, 10:57 PM #10I found that no matter where the positions are suitable for a clamp, it won't be suitable to clamp the project on the bench.
I like the idea of having clamps running in the slots and you can also have milling type toe clamps made up for extra versatility. Years ago I made some clamps from 2 bits of 25mm x 6mm welded flat sides together, but with a 13mm gap between them. You could have even bigger ones which can be quite long. This should give you the ability of clamping almost anywhere and upset Kryns plan.
22nd Jul 2017, 11:25 PM #11Most Valued Member
Thanks everyone for helping clear PFC up. In 40 years never heard of it?
At least no ones going to steel it, not with out a fork lift or crane.
I like the idea of the gaps between the channels, allows plenty of scope for clamping.
23rd Jul 2017, 09:26 AM #12
Pic - Take 3.
23rd Jul 2017, 11:16 AM #13
To answer this part of the question I would select F head sliding clamps over the G Clamp option.
Reason is that F heads are quicker and easier to use . There is a limited clamping force that could be applied unless the clamps were specially fabricated as opposed to off the rack clamps which will still need modification.
While F heads are probably the best option to make quickly there are others. Consider a selection from below that came from google pictures. The bases ,in some examples do require modification. It really dependent on the applications you have you have.
Fab clamp 1.jpgFab clamp 2.jpgFab clamp 3.jpgFab clamp 4.jpgFab clamp 5.jpgFab clamp 6.jpg
23rd Jul 2017, 11:20 AM #14
To help me with Google, does the clamp in Grahames pic have a specific name?
23rd Jul 2017, 12:12 PM #15
Google Bench Clamp and / or Surface Clamp to start the search.
Toggle Clamps.
By BaronJ in forum METALWORK PROJECTSReplies: 24Last Post: 28th Dec 2021, 12:22 PM -
G Clamps
By NCArcher in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 23rd Apr 2017, 09:46 PM -
Spiral clamps
By Michael G in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 13th Oct 2016, 02:19 PM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM
