Results 16 to 17 of 17
Thread: How to get square cornered welds
5th Oct 2017, 10:58 AM #16Senior Member
- Jul 2013
- nsw
- 256
i'm not sure what the forces are in a firebox, but expansion and contraction would be one.
with 6 mm gaps i would be tempted to slug it. ie lay a piece of mild steel rod in there and weld in.
otherwise you will have to "cold butter" it to bring edges together. cold butter like you did edges.
if the forces of heat cycling are not significant then laying filler rod in there could work too. lay extra rods with their flux removed in the gaps and melt them in.
hammer the flux off on an anvil or similar piece of concrete haha
looks like a great project !
7th Oct 2017, 11:37 AM #17Senior Member
- Dec 2012
- emerald
- 161
Thanks meadow street. I'll take your advice on the strips. It's only that wide for a short distance thankfully. I'm about to go and weld it up now, so I'll post the results tonight.
I don't think that expansion and contraction should be much of an issue because the whole system should expand and contract uniformly. The firebox is to be lined with insulating firebricks.
Eric
Need someone to look over my welds
By gazza2009au in forum WELDINGReplies: 22Last Post: 28th Apr 2015, 04:21 PM -
Some welds for you to critique
By Zumanity in forum WELDINGReplies: 20Last Post: 23rd Aug 2014, 11:30 PM -
Square tubing that's not square
By Corgan in forum METALWORK GENERALReplies: 18Last Post: 1st Nov 2011, 09:31 AM -
Pretty welds
By Dave J in forum WELDINGReplies: 32Last Post: 15th Jul 2011, 02:37 PM -
How many welds?
By Single-phase in forum WELDINGReplies: 7Last Post: 24th Oct 2009, 04:23 PM
