Results 46 to 54 of 54
Thread: TIG welding SS
18th Feb 2017, 10:56 PM #46Golden Member
- Feb 2010
- Ballina, NSW
- 900
Couldn't agree more Karl. I remember seeing one of ChuckE's videos ages ago and thinking how bad it was. Then I saw one the other day and the guy's been given some pretty good gear on sponsorship (can't remember what now). It doesn't do the suppliers any favours at all having such a moron "reviewing' their gear.
In contrast, I still watch everyone of Jody's videos, even though I would rather he just did more of each job that came through his shop, than some of his latest format.
- Mick
18th Feb 2017, 11:00 PM #47Golden Member
- Feb 2010
- Ballina, NSW
- 900
19th Feb 2017, 01:22 PM #48Diamond Member
- Jun 2010
- Canberra
- 1,322
He looks to be an OK enough welder, but a fairly ordinary designer/fabricator. And as with many yank Youtubers, has an incredibly thin skin, so when people kept on pointing out the stupid/poor/incorrect things he'd done in the comments, he decided to disable comments on his videos altogether. So while channels like Weld.com might not be gods of welding, at least they allow comments where people can point out faults and discuss them.
As for sponsorship, I'm not sure how sustainable his approach is - he was plugging Everlast way back, and now never mentions them. I think he's pushing HTP now, and Hypertherm look to have sent him the odd unit, but I suspect on loan only. I don't bother watching many of his videos any more, although I do make a point of clicking thumbs down on any video he posts with comments disabled.
19th Feb 2017, 08:49 PM #49I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
Agreed. You've got the settings in the ballpark now, now you're down to a little tweaking and more practice. One of the biggest factors in TIG, not only practice but being IN practice. I had cause to weld a few bits of exhaust this weekend, mild steel 1.6mm wall - and was reminded just how long its been since I actually ran the TIG. Think I need to might burn a few rods every now and then on various practice pieces just to keep my hand/eye coordination up to scratch - I welded a lot nicer when I was regularly doing a lot of fab work with it...
20th Feb 2017, 07:56 AM #50Senior Member
- Dec 2010
- Syd
- 492
Looking at the job, it appears something suited to spot welding. Fortunate here, there's one a few doors up I can access, have you anyone you could throw a few beers at down there to let you loose on a machine?
I'd expect that might be an exercise in frustration if not on your game 100%. There's an ex-Sellafield colleague who would have no difficulties, but he was the best I ever saw - probably make most of the others I've known to think twice just from potential distortion.
20th Feb 2017, 08:57 AM #51Philomath in training
I have a spot welder and could do this easily on it (although I'd still have to strip the coating from the sheet), but because this box will potentially be going into food production areas I wanted something with minimal external cracks/ crevices so it could be wiped down.
As far as distortion goes, the only thing that the welding has induced is that the base sheet now oil cans a little. Everything else is still where it should be.
22nd Feb 2017, 02:48 PM #52Most Valued Member
- 4,258
6th Apr 2017, 08:42 PM #53Philomath in training
Making progress and two D cylinders of argon later, things are improving.
This probably my best weld yet -
The previous material went rusty on me (as stainless often does...) so this is with genuine 0.7mm 304. For a size comparison, the slide is folded from 0.8mm galv.
(If only they were all that smooth)
7th Apr 2017, 07:40 AM #54Most Valued Member
- 4,258
Welding through POR 15
By simso in forum WELDINGReplies: 3Last Post: 18th Oct 2016, 08:37 PM -
CO2 with TIG Welding????
By iron bark in forum WELDINGReplies: 3Last Post: 26th Mar 2013, 06:47 PM -
Welding 5mm SS rod for BBQ with Oxy
By Paddy in forum WELDINGReplies: 4Last Post: 2nd Feb 2012, 09:43 PM -
new to welding.
By Bluegum in forum WELDINGReplies: 8Last Post: 24th Oct 2006, 09:22 PM -
welding tip
By mako in forum WELDINGReplies: 4Last Post: 7th Jul 2006, 04:59 PM
