Results 1 to 8 of 8
Thread: Broken Cast Iron. I need help.
2nd Feb 2017, 04:35 PM #1
Hi,
HELP!
I'm working on restoring a very old cast iron sewing table for my wife. Everything was going great until I dropped the last piece and it snapped in 3 places!
I am told Brazing is the way to go to fix this. I don't know because I cant weld.
- Opinions on welding vs brazing cast iron?
- I have a small gas torch. It's a Tradeflame Butane gas torch. See Picture. Will it get hot enough to braze? Is this something I can tackle, as someone who has never brazed anything?
- What type of welding rod do I braze with?
- Can anyone suggest a welder around Oakleigh, Victoria, who could braze this back together? I am prepared to pay. Anyone have an idea of the cost?
Thank you,
Steck
IMG_2069.jpgIMG_3017.jpgIMG_9750.jpgCheers,
Steck
2nd Feb 2017, 06:13 PM #2Senior Member
- 112
1. Options are: Oxy-acetylene fusion welding using silicon CI filler rod; properly done, the repair will be almost invisible when painted. Needs a skilled welder with understanding of expansion, contraction & characteristics of CI.
Electric arc stick welding using a nickel alloy electrode. Skilled welder as above but not quite as critical.
Oxy- acetylene brazing using manganese-bronze filler rod. Probably the most forgiving process, but expansion/contraction control is still important. The resulting joint is usually ugly due to required reinforcement.
2. No.
3. Manganese bronze.
4. Sorry, I am in Sydney.
Chas.
2nd Feb 2017, 06:54 PM #3
can't help with a recommendation of who could do the job,
but the brazing is the easy part -- the hard part is pre-heating and then cooling the cast iron in a controlled manner. Get the preheating and cooling right and the repair can be made to disappear, get it wrong and ...regards from Canmore
ian
2nd Feb 2017, 07:59 PM #4Golden Member
- Mar 2009
- 54
- 825
G'day Steck,
That should be a pretty straight forward bronze brazing repair. Your little butane torch will not be up to the job as you'll need oxy acetylene temperatures to bronze something like that.
I reckon TIG with 316 filler would give you a good workable repair as you have small relatively thick sections with plenty of room to manage expansion & contraction issues.
CI stick welding rods would do the job ok but they would be my least preferred option for fine repairs like this, harder to get small deposits and cost as they're bloody expensive.
I'm in Fawkner and would be happy to do the repair if you don't mind coming up to the wild north.
Greg.
2nd Feb 2017, 09:37 PM #5Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I have a cast iron bench seat here, that had a leg snap off when moving house, back in the '80s.
It was repaired in such a way as to be invisible when painted.
I resisted advice to grind a "V" at the joint, just heated the pre-fluxed joint with oxy-acetylene to glowing hot, then the bronze filler rod was introduced, which got right into the joint by capillary action.
I've been sitting on that bench ever since!
Jordan
2nd Feb 2017, 10:16 PM #6
3rd Feb 2017, 09:46 AM #7
10th Feb 2017, 11:59 PM #8
I just took my broken cast iron over to kwijibo99 who did an excellent job saving my cast iron with a TIG welder.
Many many thank yous!Cheers,
Steck
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM -
Cast Iron
By RayG in forum METALWORK GENERALReplies: 17Last Post: 30th Apr 2011, 02:27 PM -
Broken cast aluminium
By jmk89 in forum METALWORK GENERALReplies: 8Last Post: 3rd Jul 2006, 06:05 PM -
Repair of Broken Cast Iron
By Grahame Collins in forum METALWORK GENERALReplies: 0Last Post: 11th Feb 2006, 11:35 PM
