Results 1 to 15 of 17
Thread: Joining Aluminum Tubing
12th Jan 2017, 04:32 AM #1New Member
- Jan 2017
- Colorado
- 4
Hey all, I'm working on a school project and I was wondering what wall thickness I should get for the aluminum we're making the frame out of. The outer diameter is 1". We plan to braze or MIG weld the joints. That brings me to my second question, would brazing work? I've attached some working drawings. Thanks in advance
Edit: We are using 6061 Aluminum
12th Jan 2017, 06:57 AM #2Philomath in training
G'day aagui and welcome to the forum.
In part process choice relates to the thickness of the tube but I've welded 25mm tube with 1mm wall (1", 0.040" wt) in a mitre configuration, so you can get pretty thin if you want to. The wt is dictated as much by the strength you need. If you are new to Al welding I would suggest thicker material (maybe 80 thou or thicker) as it gives a little more margin for error
My weapon of choice for that joint was TIG. For that thickness MIG might be a bit too vigourous and a brazing process may have problems getting a decent joint given the small surface area on the ends of the tubes.
12th Jan 2017, 07:48 AM #3New Member
- Jan 2017
- Colorado
- 4
12th Jan 2017, 08:59 AM #4Golden Member
- Nov 2010
- Gippsland Victoria
- 733
At the woodwork show I've seen people selling some sort of metal rod and the promotional video shows people joining soft drink tins together.
Is this brazing ?
Google finds this video - joining two soft drink tins.
https://www.youtube.com/watch?v=AXYZ948Smbg
Bill
12th Jan 2017, 09:03 AM #5New Member
- Jan 2017
- Colorado
- 4
Yep! That's brazing, most people use that when working with aluminum because welding aluminum tends to be expensive and requires specific materials.
12th Jan 2017, 09:39 AM #6Member: Blue and white apron brigade
I don't know how expert Steamingbill's operator was but check out the TIG weld produced in this vid.
12th Jan 2017, 09:59 AM #7Golden Member
- Sep 2008
- N/A
- 535
aagui can you use those plastic joiners instead? Someone on here will know what they're called.
12th Jan 2017, 10:09 AM #8Member: Blue and white apron brigade
Cube lock connectors/joiners.
https://www.bunnings.com.au/connect-...oiner_p1138513
12th Jan 2017, 10:54 AM #9Philomath in training
That's something that you spend several years at engineer's school learning. What is the crate for?
You may be better off finding an engineer locally and going to talk to them as there are several different failure modes that you might wish to avoid (for example deflection, yield of the tube, ultimate failure, buckling)
12th Jan 2017, 12:09 PM #10New Member
- Jan 2017
- Colorado
- 4
Unfortunately Legion, I cannot. That would be helpful though, thanks for the recommendation.
≈Agui
I figured as much, just figured I'd take a chance that someone here has such experience. I've actually spent some time researching, and I'm starting to find some equations that are helpful. We're making a fully functional serch and rescue backpack that can be turned into a stretcher, I'll keep you guys updated!
≈Agui
12th Jan 2017, 12:17 PM #11Member: Blue and white apron brigade
12th Jan 2017, 08:53 PM #12Senior Member
- Dec 2010
- Syd
- 492
Brazing aluminium used to be the only way to do it - using oxy. There's a flux core rod you use, but not many left who can do it now without ending up with a puddle...old school body builders and aviation welders might be the last hold-outs! That other method, without looking at the vid, I assume is the stirring/wire brush thing, is more akin to soldering.
Assuming the tube is in a T6 state, welding it will make it T3 in the vicinity - hardening to T4 over several weeks. More than likely, there's some sort of 90 ° tube insert extrusion out there.
13th Jan 2017, 07:49 PM #13I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
13th Jan 2017, 08:16 PM #14Golden Member
- Feb 2010
- Ballina, NSW
- 900
To answer your original questions - I would pick 3mm wall thickness if you are attempting to MIG weld this - make sure you do some test welds first to get your settings and technique well sorted. I'm assuming the frame doesn't really need heaps of strength?
As mentioned above, this is an ideal job for TIG, where you could get your wall thickness down to 1.6mm if weight/cost was an issue.
I think welding would be much better than brazing those joints.
- Mick
18th Jan 2017, 03:14 PM #15
Gidday
Id also be using TIG for a primer check out how Jody from Welding tips and Tips goes about it here:
Tig Welding Aluminum Tube
Regards LouJust Do The Best You Can With What You HAve At The Time
Tapering or coupling aluminum tubing
By horseatingweeds in forum METALWORK GENERALReplies: 22Last Post: 13th Oct 2016, 09:12 AM -
Joining two 8mm shafts. Best way?
By jhovel in forum METALWORK GENERALReplies: 18Last Post: 7th Feb 2016, 12:28 AM -
Joining nails - need help.
By JustWondering in forum METALWORK GENERALReplies: 2Last Post: 16th May 2007, 06:08 PM
