Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Brazing here?
  1. #16
    Oct 2004
    Southern Highlands NSW
    1,898
    Thanks for the caution.
    There's no work being done over Xmas.
    Do you mean the sleeves or flanges should be brazed, or otherwise connected together?
  2. #17
    Nov 2010
    Gippsland Victoria
    733
    Ive seen various brands of supermagicfixitsilicone tape in the hardware shops.
    Rolls of it like masking tape, supposed to set like steel.
    Could you wrap that around your leaking joins ?
    Not ideal I know.
    Bill
  3. #18
    Oct 2004
    1,898
    Thanks Bill, I'll mention it to the owner.
  4. #19
    Nov 2015
    Brisbane Australia
    85
    I would use a mild steel filler rod and a #8 tip on the oxy and fusion weld it.
    You start by creating a small pool of hot metal and adding the filler rod to fill in between the two pieces.
    It is easy to do, you control the heat by pulling the torch closer or further away.
    Don't force the tip with to much oxygen, you can tell by the noise.
    I am a plumber and I would do it that way not with bronze rods.
  1. Brazing Carbide
    By Tiger in forum WELDING
    Last Post: 6th May 2010, 11:43 PM
  2. Arc brazing
    By verm in forum WELDING
    Last Post: 10th Mar 2010, 06:35 AM
  3. Brazing
    By garym in forum METALWORK GENERAL
    Last Post: 9th Aug 2007, 12:12 AM
  4. Help with brazing with MAP
    Last Post: 5th Nov 2006, 03:28 PM
  5. Brazing with a TIG
    By Rossluck in forum METALWORK GENERAL
    Last Post: 11th Sep 2006, 08:23 PM
