Results 1 to 3 of 3
    Aug 2016
    NSW
    15
    Default Hardfacing question
    Hi, I have a loader bucket that has been hard faced before using a waffle pattern, but I don't know what sort of welding wire was used. It needs doing again & I would like to ask if it is ok to weld directly over the old hard facing or should I lay the new weld next to the old?
    I am going to use Kiswel K-700HT wire.
    Regards WC57
    near Rockhampton
    6,217
    When you hardface the first run dilutes itself with the base material so is never as hard as the next run on top.
    I would grind the existing hardface to remove any imbedded dirt/rock then run over the top. If you put some thought into it you might not have to hardface too much. I have seen some people go a bit over the top.
    Aug 2016
    NSW
    15
    Thanks RC, the outer edges are still fine so I will do as you suggest & repair what is needed.
  1. Yet another DRO question
    By familyguy in forum METALWORK GENERAL
    Last Post: 7th Aug 2016, 05:33 PM
  2. TIG question
    By pajeronj in forum METALWORK GENERAL
    Last Post: 20th Jul 2011, 02:45 PM
  3. Question regarding VSD/VFD
    By Com_VC in forum METALWORK GENERAL
    Last Post: 22nd May 2010, 08:12 PM
  4. Hardfacing lawnmower blades
    By .RC. in forum WELDING
    Last Post: 27th Feb 2009, 10:56 PM
