Results 1 to 12 of 12
14th Nov 2016, 08:24 PM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Welding at night any tips and tricks?
Hey Guys
looking to do a bit of night welding if possibly just to save on argon using sold wire outdoors, night time there is little to no wind
can anyone offer some advice on lighting, where to position the lighting, what lighting works best and so on?
i tried googling for help on night welding but it only gave pages of night welding course's
14th Nov 2016, 08:53 PM #2Senior Member
- Jan 2015
- 211
Keep the light away from your back, you will get a reflection in your hood and it will you. A couple fluro lights or leds will be fine, you may need to up the sensativity on your hood to stop it darkening from the light.
Personaly i like to weld in the dark with no lights. Helps me focus and see a bit better.
14th Nov 2016, 09:20 PM #3Philomath in training
- 6,563
14th Nov 2016, 09:31 PM #4Most Valued Member
- Aug 2009
- 1,844
Thanks Brendanh and Michael
I have a small hand held work light with a fluorescent globe about 26watts if i cant see i will try a factory light 150watt metal halide
i just wasnt sure about the whole welding at night thing because it isn't talked about much from my researching
going to tackle it this week so fingers crossed
15th Nov 2016, 01:09 AM #5Golden Member
- Sep 2008
- N/A
- 535
You can buy led floor lamps that light up the area like day time from chain hardware stores. Like this:
https://www.bunnings.com.au/arlec-90...ripod_p4380378
15th Nov 2016, 06:06 AM #6Most Valued Member
- Aug 2009
- 1,844
Awesome thanks Legion i will keep an eye out for one of these on ebay i may even make my own from aluminium stand, i have used the 10w LED floodlight before but it wasn't very bright the one u linked is two 45watts so may be alot brighter i'll look for something in similar wattage
15th Nov 2016, 07:46 AM #7
Wouldn't it be easier to erect a wind-break and weld during the day?
15th Nov 2016, 08:23 PM #8Most Valued Member
- Aug 2009
- 1,844
I went to bunnings to see what they have and found a 500watt halogen light which is portable its working great and with some left over aluminium i plan on building a stand for the light so i can cover a broader area
i didn't want to invest to much money into a light because i wasn't sure if i would be able to weld or even see at night but so far its working very nicely indeed the only thing the neighbours may complain about the welding noise but it only last 2mins for the duty cycle every 10mins
i was welding earlier today while there was no wind than later in the afternoon the wind kicked up so i packed up and unpacked again just before dark, i was using double the amount of argon welding during the day than i am now at 8pm
Gavin what sort of wind breaker do u have in mind? i thought about using a gazebo but they are costly $150+ and it could be a fire hazard
15th Nov 2016, 08:37 PM #9
I just have some old sheets of plywood with gate type hinges attached so I can link them together to be self standing and arranged to suit the needs of the job site.
16th Nov 2016, 03:22 PM #10Novice
- May 2013
- Murrumbateman
- 11
One thing I found with night welding is that you need to hold the solar panel on your welding helmet in front of a light for a bit to make sure it's charged.
Nothing worse than the auto darkening not working on that first strike.
Dave.
18th Nov 2016, 08:43 AM #11
Maybe affix one of those LED lenser head lamps to your helmet I reckon they would be bright enough too see even while your welding, they are brilliant out camping and fishing
18th Nov 2016, 08:07 PM #12Most Valued Member
- Aug 2009
- 1,844
The light is bringing a million moths to the party they are so attracted to the light they are dying all over the job freshly fried don't tell the greenies
Share your weld software at Welding Tips and Tricks
By Grahame Collins in forum WELDINGReplies: 0Last Post: 31st Jul 2016, 08:55 AM -
By Blu_Rock in forum WELDINGReplies: 6Last Post: 31st Jan 2016, 01:06 PM -
Tips and tricks for welding
By matthew_g in forum METALWORK GENERALReplies: 1Last Post: 10th Jun 2010, 12:38 AM
