Results 1 to 15 of 16
20th Jul 2016, 08:09 AM #1
Why do my welds look like this? (flux core, gasless MIG)
My tested weld run on a spare piece of the steel plate was okay, but this happened when I tried to weld the same steel to a steel door jamb.
Vertical weld, I tried slow and fast spool speed, low and high current (my SCA welder only has 60 or 100A setting), running down and pushing up ... still got sloppy welds like this:
20th Jul 2016, 10:11 AM #2Senior Member
- Jul 2013
- nsw
- 256
vertical can be a bit tricky.
check this video on wire feed speed first
Setting Wire Feed video
once you get a puddle going then a slight side to side manipulation will help you as you progress the weld upward............some guys like a pronounced weaving side -to -side action with a slight pause on the end of each weave.
often called a "Z weave"
there are some great videos on YouTube about vertical mig welding and some on fluxcore too if you have the desire for visuals
fluxcore ( like mig) requires the right balance of volts (power min or max in your case) and wire feed speed......getting the balance right is important, so check to see if there is a chart of recommended settings for your particular welder.
if no chart then :
try setting the power switch on max and adjust the wire feed knob untill you get a nice smooth bead with no stubbing or other irregularities and a good crackling sound.
do the same for the machine set on the minimum switch and decide between the two which will suit you application the best.
lincolnelectrictv on YouTube has some good trouble shooting tips on fluxcore welding but not necessarily vertical. weldingtipsandtricks on YouTube can give you some hints on vertical mig too.
anyhow, keep practicing and if you are unhappy with the door weld then grind it out once you feel more practiced in vertical and reweld it.
good luck
ps more pictures would help, plus the settings next to the welds give great info for us amateur weld inspectors hahahah
20th Jul 2016, 10:26 AM #3Golden Member
- Sep 2008
- N/A
- 535
What's the door jamb made of? Zinc plated steel? Did you clean it off?
Sorry, can't help with mig welding. But it does look like it wasn't nearly hot enough.
20th Jul 2016, 11:20 AM #4Diamond Member
- Jun 2010
- Canberra
- 1,322
I'd say too low wire speed, hence the series of blobs rather than a continuous bead.
20th Jul 2016, 04:07 PM #5Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Adding to meadow street's YouTube recommendations, I've found ChuckE2009 really helpful for tutorials and troubleshooting https://www.youtube.com/channel/UCJA...b5sg79yld7T3hA
20th Jul 2016, 04:36 PM #6Senior Member
- Jun 2016
- 283
Looks to me as though you never got the arc onto the shiny bit of steel. If you are running at low power, which this seems to be, then you really need to puddle the melt carefully.
Roger
20th Jul 2016, 09:04 PM #7Most Valued Member
- 5,942
Could you post a pic of your test weld please, also was the test piece done in a vertical position or on the flat? Did you move the welder any distance, use an extension cord, or anything else. Using an extension cord, if on the light side, can cause a drop in power available. Use a heavier ext. cord and as short as possible, on any jobs.
20th Jul 2016, 11:01 PM #8
20th Jul 2016, 11:55 PM #9Most Valued Member
- 5,942
Hi Joe,
I asked, if the test weld was done in a vertical or on the flat. Have rephrased the question to validate this. (I faled inglis at skool.) The reason for asking is that changing from flat to vertical would require a different setting.
21st Jul 2016, 02:15 AM #10
You are right, Kryn. I misunderstood your comment. Usually you don't need to and can't really change much other than wire feed on these low end welders. Once you have found the right speed for the wire size and high and low voltage output, you can leave it alone. On mine the feed motor is actually connected via a rectifier diode to the welding output and the wire speed changes when you change voltage. That happens to match by chance or design. SInce I only ever use one size wire, I donl;t have to touch anything other than setting the voltage to high for material over 2.5mm and to low under that. The width of the weld and fillet size is controlled just by my welding speed. Vertical up is no different to down hand and I find vertical down impossible with gas less wire.... Overhead (not above my head! but welding underneath something) is OK too.
The biggest issue is the 'messy' splattery look of the surrounding 2 inches or so... Using lots of anti splatter spray helps a bit for cleaning up.
One day I'll get a 'proper' MIG....Cheers, Joe
21st Jul 2016, 08:24 AM #11
NathanaelBC,
First of all,Welcome to the Forum.
In the absence of much of the information needed to provide you with an adequate answer,I will try and guess to fill in the gaps.The SCA 100 amp welder is a cheaply priced gasless wire feeder.
Being cheaply constructed ,it does not have the features which would enable you to weld a wide range of different thickness metals.
At a glance I would say your door jamb is a much thicker metal than your original piece of metal.That means an entirely different setting was required for the second (door jamb) weld.
The deposition reads like a book to me.Voltage setting and amps -way too low.
This machine - bearing only two heat settings ( voltage taps) was not physically able to provide that setting needed - whether it was the specific setting used or if it was just under powered for that job- hard to say..
If it is to work at all ,the most likely setting to work for the door jamb weld will be High voltage ( High/ Low rocker switch on High) and wire speed (the dial) up near 100 amps.
Try 12-15 mms of wire stick out and see how that goes. Make sure your earth clamp is contacting to clean shiny metal - give the metal a touch up with the grinder.
Settings for vertical welding don't vary greatly from those on flat.Its the manipulation of the torch/gun that is important.
As the others have said watch a few videos on the subject of vert welding with flux core gasless wire.
Good Luck
22nd Jul 2016, 08:32 AM #12
Thanks everyone for the feedback, I'll go get some more info on the settings I tried and get back to you ...
The door jamb steel I assume was coated, but I used a brass wire cup on a grinder and stripped it back pretty well. It's the same thickness as the mild steel plate I was welding onto it.
I'll check the tips, clamp etc.
You know, I haven't even checked the polarity of the welder - I assume it's tip negative given it's only a gasless machine, but you never know!
12th Nov 2016, 12:20 PM #13
Well, I know it's bad form to blame your tools but that really was a crap welding machine; got it on sale for $200 from Supercheap and it was fun to play with and learn from but it was pretty limited given just two voltage settings and fixed electrode positive polarity which isn't ideal for flux core.
So I just upgraded to still affordable but much more featured UniMig Razorweld 175 and have just been practicing with it, using argon mix shielding gas and solid wire SO MUCH BETTER.
I still have a lot of learning and practice to do but now I have hope I can actually do useful welding not just making ugly beads of wire.
12th Nov 2016, 07:44 PM #14
Nathanael.
Congratulations on your new purchase.
If I recall the Unimgs had a pretty fair instruction book. It should be a big help in getting you sorted for the run settings
Can we look forward to some pics of your welds and that will make it easier to to fine tweak your machine?
14th Nov 2016, 08:19 PM #15Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
As mentioned the guy on Youtube ChuckE does some useful videos, he done one on how to set a MIG's wire feed and heat setting using a multimeter, a stop watch and a ruler
i dialed my new machine in the other day to ChuckE's video and ran a beautiful weld on aluminium i also used the Lincoln online calculator for wire feed speed
Flux core mig wire
By tonyhothe in forum WELDINGReplies: 1Last Post: 2nd Oct 2015, 06:44 PM -
Flux Core Vs DC Arc
By blumx in forum WELDINGReplies: 14Last Post: 27th Jun 2013, 10:49 PM -
Using argon mixture on a CO2 flux core wire
By beefy in forum WELDINGReplies: 20Last Post: 21st Dec 2012, 06:08 PM -
Can you use flux core wire in an old gas mig welder?
By cant_arc_weld in forum WELDINGReplies: 4Last Post: 25th Jul 2011, 08:16 PM -
flux core wire
By danielhobby in forum WELDINGReplies: 0Last Post: 11th Sep 2010, 11:58 AM
