Results 1 to 4 of 4
    Oct 2008
    Nth N.S.W.
    62
    52
    Default Spot welder question
    I would like to buy a portable spot welder. I have used an italian made unit that worked good.( like those sold by the larger machinery stores that sell for approx $1000) looking at using it on metal duct work for dust extraction and light home workshop use.
    does anyone have experience with the units that are sold on ebay? for about $350
    I am guessing they are made in china etc? do they last? and do the tips need replacing often? is their duty cycle reasonable?
    any information would be greatly appreciated.
    May 2011
    Murray Bridge S Aust.
    5,956
    Could you paste a link to the one you like. Have used a Toolmac unit that worked quite well, about the same quality as the ones listed on Ebay. The duty cycle of 30% worries me a little, but I suppose that by the time you assemble the various components, it will have cooled down enough to continue. Just remember they are not a production unit.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I have an old Dorman unit which I use occasionally. Thinking about it, a 30% duty cycle is not too bad (say 1 second on, 2 seconds off - sounds reasonable). Tips and regrinding is really a matter of use - if they get too hot they will suffer but used sensibly on a 'portable' unit like you are suggesting should last for some time.
    Oct 2008
    Nth N.S.W.
    62
    52
    thanks for the info. the italian made units that I have used before had a timer. the units on ebay seem to only have a switch, so I am guessing there is not a lot to go wrong with them? as mentioned, yes I am use to keeping the tips in good order and not over doing the duty cycle. for memory the units I have used before had only a small duty cycle. eg: waiting between each spot.
  1. NZ Swap on the Spot Gas
    By KBs PensNmore in forum WELDING
    Last Post: 21st Feb 2015, 11:58 AM
  2. DIY spot welder questions
    By jhovel in forum WELDING
    Last Post: 24th Mar 2013, 12:46 AM
  3. Replies: 2
    Last Post: 2nd Nov 2012, 06:10 PM
  4. Spot Welder
    By Keith_W in forum WELDING
    Last Post: 5th Apr 2009, 09:16 PM
  5. Where to get spot weld drill bit from?
    By Com_VC in forum METALWORK GENERAL
    Last Post: 24th Jan 2008, 07:53 PM
