Results 1 to 4 of 4
Thread: wood heater
14th Jun 2016, 09:26 PM #1Most Valued Member
- 4,258
wood heater
I have to get a move on and make this wood heater using brake drums. I was thinking of getting a rolled section to fit in between the 2 drums.
Could this be made out of say 300h x 50mm wide flat steel vertical slats welded so as to form the rolled section I was thinking of?
15th Jun 2016, 09:09 PM #2Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Definitely could and can be done that way. I have never made one, but I remember seeing a picture of one made like that. I just searched one the Internet and found a Picture of one using flat bar to make the middle section.Brake Drum Heater.jpg
All The Best steran50 Stewart
16th Jun 2016, 08:51 AM #3Most Valued Member
- 4,258
16th Jun 2016, 09:34 AM #4
I made one years ago and used 2 drums off super singles. With the 2 drums lip to lip it made the firebox about 500 mm high. The lid formed a hatch to drop the wood in as well as a moveable baffle to hook up the chimney. The bottom has a drawer in it to remove the ash. I used a dust band which lifted the whole thing up about 100 mm. To join the rims I just used some 100 X 40 X 6 mm tags bolting the 2 rims together.
When I lit it up the first time it was a while before I could get any heat out of it because the cast is nearly 25 mm thick. Once alight and going it sure pumped the heat outJust do it!
Kind regards Rod
pot belly wood heater design
By gallegos in forum METALWORK GENERALReplies: 37Last Post: 8th Nov 2020, 10:57 AM -
Rocket Mass Heater
By Gestalt in forum METALWORK GENERALReplies: 15Last Post: 22nd Jul 2014, 07:58 PM -
Rocket Heater
By gngh in forum METALWORK GENERALReplies: 3Last Post: 19th Jul 2013, 10:51 AM -
whats a good welder? welding 10mm / 12mm steel mig gas or gasless wood fire heater
By makitaLXT in forum WELDINGReplies: 3Last Post: 30th Jun 2013, 10:58 AM -
Truck Brake Drum Shed Heater
By Big Shed in forum METALWORK GENERALReplies: 12Last Post: 16th Jun 2011, 09:27 PM
