Results 16 to 19 of 19
17th May 2016, 07:49 PM #16Diamond Member
- Jun 2010
- Canberra
- 1,322
18th May 2016, 10:45 AM #17
The comment was not meant to be disparaging to DIY welders though I concede I may have put it the wrong way and upset anyone..Apologies to any who have taken it this way.
Satincraft are susceptible to problems stemming from use with a long arc length. New welders have a problem in maintaining a consistent short arc with the electrode,the result being that the arc has not got the "grunt" to penetrate the viscous molten flux. On a perfect set up amps and a perfectly clean sample coupon that is not plated the flux does a very good job of providing that nice ripple finish.
However on DIY work, apart from incorrect amps setting there is often dirt rust and a plated surfaces to contend with, which the flux does not not perform its primary function of cleaning the the molten weld pool very weld at all.
Obviously flux formulas are a bit of a compromise between weld bead bead finish and scavenging of the molten weld pool.Most other electrodes are fluxed in favour of weld pool scavenging and cleaning and suffer less from a longer arc length being held.
With satincraft the setting and arc manipulation have to be spot on and not all DIY welders are at this level. My opinon for what it is worth, is that they do get suckered in by the undeserved reputation of the electrode for its finish and believe its THE electrode to use.
22nd May 2016, 11:35 AM #18Member
- Dec 2010
- nsw
- 51
Strongly agree with post #17 regarding satincraft , in fact would say they would have to be the worst electrode in their category that I can remember using, as stated before slag trapped in the weld appears to be the main problem along with their high cost. Would not buy them.
Have found WIA 12P or Magmaweld ESR11, a big improvement.
22nd May 2016, 02:22 PM #19Senior Member
- Apr 2013
- Bunbury WA
- 98
Have to agree on the Satincraft, my old standby is Weldcraft but used some smootharc recently and they were very similar.
Help with corner to corner join
By Tegmark in forum WELDINGReplies: 10Last Post: 25th Jun 2015, 06:27 PM -
12mm plate with small MIG?
By brendanh in forum WELDINGReplies: 11Last Post: 22nd Mar 2015, 05:24 PM -
Internal corner technique
By Legion in forum WELDINGReplies: 2Last Post: 21st Oct 2013, 09:23 PM -
Some home made corner clamp tools
By Corgan in forum METALWORK GENERALReplies: 13Last Post: 30th Nov 2011, 12:06 AM -
Triton corner and straight. brackets
By masu in forum METALWORK GENERALReplies: 5Last Post: 15th Sep 2007, 05:25 PM
